Sponsored by: Auxito
Front end noise
Old Apr 24, 2011 | 08:12 AM
fordguy4life's Avatar
fordguy4life
Front end noise
Hey guys,
I've got a '99 F150 with 200k+. I've got a noise that sounds like tire noise, speed related, seems to go away when turning either direction. I just put Bridgestone dueler rh-s on the truck about 6000 miles ago. I rotated the tires and the noise doesn't go away. Its not as noticeable at highway speeds. What do you guys think? Wheel bearing? Front diff??
Old Apr 24, 2011 | 12:48 PM
steve(ill)'s Avatar
steve(ill)
the "goes away when turning" leads one to believe it is a wheel bearing... this is a 4 x 4 ?
Old Apr 24, 2011 | 09:19 PM
DaleD's Avatar
DaleD
I'm leaning towards a wheel bearing also. On mine I got 150k on the driver side and 200k on the rider side on a 97 f150 4x4. They don't cost to much now, you just have to figure which side it is .
Old Apr 25, 2011 | 06:33 AM
fordguy4life
Sorry. Yep, 4 X 4.
Old Apr 26, 2011 | 04:24 PM
fordguy4life
Sure seems like the bearing...Looks like I've got to replace the whole hub. Cheapest I could find was $185. Ouch.
Old May 1, 2011 | 07:45 AM
fordguy4life
Was the bearing.....replaced the hub, and sound is gone. Thanks guys!
Old May 1, 2011 | 09:30 AM
DaleD's Avatar
DaleD
How bad did it set you back ?
Thanks
Old May 2, 2011 | 08:47 AM
fordguy4life
I might regret it, but I used O'reillys house brand. I was a little hesitant.
It was $118 plus tax. Their "premium" brand was $214. All of the other parts stores I checked were 165 for their cheap ones.
I torqued it to 221 ft pounds....We'll see how it long it lasts. Wonder if it will go 200k?? Doubt it...There's a year warranty so what the heck.
Wasn't a bad job if it wasn't for a caliper bolt breaking.
Thanks for the tip guys.
Old May 7, 2011 | 07:27 AM
fordguy4life
If anyone else has one go out DO NOT use the cheaper "house" brands. Started wobbling and making noise after 500 miles. Swapped with a National hub now. $100 more. You get what you pay for I guess...
Old May 7, 2011 | 11:07 AM
DaleD's Avatar
DaleD
First one I paid $155.00 Michigan bearing, and the last one came from O'reilys where my son works, got his discount and it cost $63.00 and it works just fine. !!
Old May 8, 2011 | 09:55 AM
fordguy4life
The guy at the parts store says they get a lot of warranty claims on the house brand.
02towwannabe
All Things Towing
26
Feb 12, 2017 04:12 PM
happylogan1
2009 - 2014 F150
Mar 16, 2013 06:14 AM
tfdcapt
Oct 11, 2007 06:58 PM
Mazatrol
15
Jan 28, 2006 08:09 PM
jim0517
Dec 30, 2004 10:17 AM
