I need some help with replacing a broken lower mirror on my driver's side. Truck is a 2012 F350 XLT 6.7 Diesel. I have pictures below of the mirror and an alleged fit replacement that I ordered. I don't have the original anymore. What part should I order to replace the lower mirror?
I checked out this site, and its recommending a slightly different part / kit:
There is not a good picture of the back of the mirror on the part page, and the other versions I've seen on Amazon etc. are similar to the part that doesn't fit.
Receiver on truck Back of broken mirror (now gone) 9C3Z-17K707-B replacement mirror, doesn't fit.
When I bought my F-450, it had a lower mirror that was cracked. It also wavered as you drove along. Found you can get a new replacement mirror, but you can't get the clips that hold the mirrors into the assembly. So I just bought the cheapest replacement mirrors found on Ebay. They came with the proper wiring, put them on and they work great. Found a video on Utube that showed exactly how to take the doors apart to replace the mirrors.
