Spark plug issues
Old May 10, 2022 | 02:31 AM
Fta5169's Avatar
Fta5169
Spark plug issues
4.6l has a misfire on #7 I have already changed the plug, coil pack and fuel injector and still punching up as a misfire!! Anyone?????
Old May 10, 2022 | 05:01 AM
JWA's Avatar
JWA
Is that plug before it was replaced? Looks to be tons of carbon on the bottom threads, naturally the electrode and grounding strap are missing too.
An ill fitting chassis wiring connector to the COP could be the cause of this, perhaps an issue with the #7's wiring circuit path back to the PCM?
Old May 10, 2022 | 05:42 AM
Fta5169's Avatar
Fta5169
This is after I changed everything! I can't even drive 30 miles without this happening!
Old May 10, 2022 | 11:50 PM
Beechkid's Avatar
Beechkid
Fuel injector..........................
Old May 11, 2022 | 05:20 AM
Fta5169's Avatar
Fta5169
if you read what I wrote I already changed it!!!
Old May 11, 2022 | 08:35 AM
projectSHO89's Avatar
projectSHO89
Has the #7 plug hole ever suffered a blowout and attempted repair?
BTW, what year is this engine? That's important information...
Old May 11, 2022 | 09:30 AM
Fta5169's Avatar
Fta5169
it's an 06 and yes it has had a helicoil put in and it was fine mechanics said it's still in good shape!
Old May 11, 2022 | 11:49 AM
projectSHO89
I'd disagree with the mechanic's assessment that it's "in good shape".
It sounds more like the plug is unable to properly seal and that cylinder is sucking excess air and is having blow-by. This causes greatly elevated combustion temps and results in burned plugs. Could also be a valve or piston got dinged during the "repair". A compression test of that cylinder would be useful to rule out this possibility.
I'd recommend removing the "helicoil" and installing either a Timesert or CalVan/Snapon or Lock'n'Stitch insert.
Old May 18, 2022 | 12:10 AM
R&T Babich's Avatar
R&T Babich
Agree with projectSHO89, need to do a compression test.
Timesert has Big-Sert Oversized inserts to fix helicoil repairs.
How many miles are on the helicoil repair?
Give them a call and see what they say.
Old May 25, 2022 | 10:48 PM
SDDL-UP's Avatar
SDDL-UP
It's my understanding if a mechanic recommends a heli-coil repair - run the other way!
Old May 26, 2022 | 05:03 AM
JWA's Avatar
JWA
Generally I'd agree especially since there are a few much, much better alternatives to an ejected spark plug thread repair.
Mrlarryhaug
2004 - 2008 F150
May 12, 2022 11:23 AM
Sean11
2004 - 2008 F150
23
Mar 3, 2020 05:51 PM
J. Bradd LaRocca
2004 - 2008 F150
Feb 1, 2020 08:17 AM
sgc2c
Jan 22, 2020 02:48 PM
Serapium
1997 - 2003 F150
15
Oct 15, 2019 08:23 PM
