Anyone ever fitted ABS sensors to a Ford 9” axle (‘65 - ‘72) ?
I need a wheel speed input for my Gearbox that would come from the ABS unit, it takes an average of the 4 wheels speeds to provide a signal to the gearbox (and speedo)
so ideally need to fit ABS sensors to each corner even if I don’t run the ABS
I just drew the trigger in CAD and had it laser cut
I put the drums in a lathe and turned a register for it to sit on
I’m changing the speed sensor to the one shown as found it’s not compatible with the Jaguar ECU.
l’ll post more updates as i progress
