Trans out again?
Old May 6, 2022 | 08:07 AM
Kwikkordead's Avatar
Kwikkordead
Just get it over with and pull the transmission. If you've done all the external fixes, there's nothing left to do outside. And given the poor track record of the pilot bearing on this design, my money is on a failed bearing. Mine's been out 5 times now for that very thing.
Old May 6, 2022 | 06:13 PM
Jamon Norton's Avatar
Jamon Norton
Shifter being stuck was the bolts that hold it had backed out again with locktite. Bolts put through this time with lock washer, nut, bolt and locktite. Still intermittent hard shift due to clutch not fully working I believe. Trans is probably coming out again. I have the updated shift fork and a oilite bronze bushing to use this time hopefully it holds. On another note I have a vibration that I don’t think is axle wrap might be worn out rear diff.
GotThreeOfThem
Oct 19, 2012 04:05 PM
rb8612
27
Apr 10, 2011 08:10 PM
ts_stroker
13
Mar 12, 2008 07:53 AM
low92flareside
Nov 16, 2004 11:54 AM
