muffler delete pipe
Old May 2, 2022 | 12:45 AM
james_1988f250's Avatar
james_1988f250
Question muffler delete pipe
Does anybody know of a pre-fab muffler delete pipe online that would replace the muffler in this system: https://www.summitracing.com/parts/f...-250/year/1988.
Muffler length is 28 inches and offset inlet offset outlet. Pipe diameter is 3in. I'm having trouble finding one and I want to try and do it myself rather than bringing it to a shop especially since a lot of shops wont do it here in california.
Thanks
Old May 2, 2022 | 10:31 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
There is no prefab part for that, two 45* angles will do that with a piece of straight pipe.
Which then begs the question as to why buy a kit when you just want to lop the muffler off?
Old May 2, 2022 | 10:37 AM
james_1988f250
just wanted something that would be clean and simple to set up. Yeah two 45s and a straight would be pretty easy.
Old May 2, 2022 | 11:13 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
I put a Flow catback kit on my 4.9 recently, I like it. Fit and fitment was good to me, I axed that turn down and cut if off square. Installed a modest tailpipe tip.
https://www.ford-trucks.com/forums/1...frijole-3.html
Old May 2, 2022 | 11:56 AM
james_1988f250
sorry i misunderstood the question, the flowmaster kit was already on the truck when i bought it. I want a straightpipe with the cat still on, it sounds rly good with the 460, not too loud. A friend of mine has that setup with a single side dump
Old May 2, 2022 | 12:31 PM
Hit Man X's Avatar
Hit Man X
Ah okay, now it makes sense. Just pick up a few 45* mandrel bends in 3" and a section of straight pipe. Mock it up and weld it in. Easy.
Old May 2, 2022 | 12:57 PM
wwhite's Avatar
wwhite
lol, I thought you were buying the kit new.
Old May 3, 2022 | 10:22 AM
james_1988f250
Went with two 45 degree elbows and a straight pipe and clamps from Summit, all in $100. Pretty good. And I can rent a pipe cutter at my local oreilly. I don't have a welder or experience with welding yet so im going with an interlocking clamping setup.
Old May 3, 2022 | 10:43 AM
wwhite's Avatar
wwhite
My last exhaust, I used these clamps "Walker 36435 3" aluminized narrow band exhaust clamp", with narrow slots cut in the edge of the slip fits.
A simple, single band saw but hand should do it, and don't over do it, just 1/2-3/4" and not too much the clamp will not cover it.
Flowmaster slip fit, well the latest ones anyways, have a 'zigzag' cut at the edges to make clamping easier. Imagine clamping where the 'zigzag' is, will tighten up very nicely.
Old May 3, 2022 | 11:22 AM
james_1988f250
The clamps I purchased are specifically made to clamp and seal O.D. and I.D. pipes together. Made by Summit Racing
Old May 3, 2022 | 11:28 AM
james_1988f250
They are quite a bit wider and have two sections and multiple bolts
dpayne7571
Mar 30, 2019 07:47 AM
lakewood
Mar 22, 2013 05:18 PM
sflem849
Jan 9, 2008 09:59 PM
whitetr
13
May 14, 2007 05:02 AM
captain p4
Exhaust Systems
Aug 27, 2004 09:28 AM
