Muffler Delete Pipe
Old May 12, 2007 | 11:45 AM
whitetr's Avatar
whitetr
Muffler Delete Pipe
Has anyone on here purchased the stock muffler delete pipe from Pure Diesel Power? As like many of you, I can't afford to drop the coin on a 5" cannon right now and would like to do something in the mean time.
Any info would be appreciated.
Old May 12, 2007 | 02:25 PM
IDPisan's Avatar
IDPisan
When i did my muffler delete I took it to the muffler shop. they took out the muffler and welded the delete pipe for 75.00. delete pipe included.
Old May 12, 2007 | 09:33 PM
jrciii56's Avatar
jrciii56
There are some muffler shops that are starting to carry 5in pipe. Just take it there pay for there service. I got a delete pipe installed and a 5 to 6 inch tip for $115. Hard to beat that.
Old May 13, 2007 | 10:46 AM
mikeb2's Avatar
mikeb2
I just took mine to local muffler shop and had a delete pipe installed. He did a great job and it is not too loud as I was afraid of and it definetely flows better. $100.00 bucks. MB
Old May 13, 2007 | 11:33 AM
mybigredford's Avatar
mybigredford
i just bought a 3' piece of pipe from a muffler shop 45 bucks and an hour of my time later i was done.
Old May 13, 2007 | 11:40 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
When I first bought my truck, I did just as these guys did. I had the local muff shop weld me me up a piece and I bought a 6inch Silverline tip. $120 out the door, the tip was the most expensive thing.
Old May 13, 2007 | 06:14 PM
whitetr's Avatar
whitetr
Thanks for the input.
I just did my buddies 97 f250, bought the pipe and welded her in. Looking at my 03 f350, the pipe enters the muffler at the bottom and exits out the top making a straight piece of pipe not the easiest install. The one from PDP says it is mandrel bent and fits right in place.
The local muffler shops around here are a little on the not so bright side from the phone calls that I have made to talk to them about doing this, so I am looking for an easier way of doing it than through them.
Thanks again for all of your input.
Old May 13, 2007 | 07:55 PM
empiretc's Avatar
empiretc
they charged me $25 to do the muffler delete at a local shop. I really want to get a ss tip. Any recommendations?
Old May 13, 2007 | 09:36 PM
mustang_gt_350's Avatar
mustang_gt_350
for everyone who has responded to this post that has done the delete.
going by the seat of your pants dyno can you tell anything has been changed? or is this just mostly a sound mod?
Old May 13, 2007 | 09:48 PM
mybigredford
i mostly have noticed more sound, and maybe just a hint more power, noticed it more on the highway when passing, but who knows, could just be a mental thing
Old May 13, 2007 | 09:52 PM
mybigredford
Originally Posted by whitetr
. Looking at my 03 f350, the pipe enters the muffler at the bottom and exits out the top making a straight piece of pipe not the easiest install..
all you have to do is loosen the clamp on the bottom pipe and grind off the little tab or button on the joint and then i used a big pair of slip joint pliers and turned the pipe 180 deg and the upper pipe and lower pipe are darned near a straight shot at eachother.
Old May 13, 2007 | 10:13 PM
empiretc's Avatar
empiretc
Lower EGTs and the cool sound.
Old May 13, 2007 | 11:44 PM
whitetr's Avatar
whitetr
I didn't even think about that.... I will have to order me a section of pipe and do it. Thanks for the info.
Old May 14, 2007 | 05:02 AM
Izzy351's Avatar
Izzy351
If I recall correctly, the piece of pipe in front of the muffler can be loosened at the clamp and rotated 180* to make a straight piece of pipe fit right in. I considered that route before I went with the SS MBRP a couple months ago, so it's been a while since I looked at the stock stuff...
Joe
