E40D BB matching bolt pattern 4r100?
Old May 2, 2022 | 10:52 PM
Arden's Avatar
Arden
Anyone know if there is a 4r100 with matching bellhousing bolt pattern to the Big Block E4OD that is behind the 7.5l 460. I know there are pump and solenoid pack differences just looking for options for a new case and hard to find the info without having options in hand
Old May 3, 2022 | 02:36 AM
wwhite's Avatar
wwhite
Nope.
You won't find a 4r100 case for a BB, 460 or a 385 series engine, no such thing.
Probably no such adapter either, its the internals that are 'similar', and some of those similar parts swap to the e4od no problem.
What are you wanting to do?
Old May 3, 2022 | 03:18 AM
Arden's Avatar
Arden
I was just trying to figure out options. I have a 4r100 out of a 04 excursion gas sitting around and a friend that is in need of a trans for a 96 f250 460. Was trying to figure out if it would bolt up but my assumptions appear correct with it being no.
not a problem Found one out of a 91 local to me so I’ll just grab that and upgrade internals during rebuild. Unless there is any other issue you can think of using the older 91 in a 96? thank you for the help as well
Old May 3, 2022 | 11:40 AM
ZSK's Avatar
ZSK
If it's a gas trans you can go with an adapter but it's around $2500 with a controller.
https://transmissioncenter.net/shop/...ber-fo1002501/
You're probably better off sourcing a good case and rebuilding with upgrades.
Old May 3, 2022 | 11:47 AM
Arden's Avatar
Arden
Thank you yeah I’ll just rebuild and avoid adapters for that cost
Kirk-NJ
Feb 23, 2020 02:43 AM
fuzz710
Mar 21, 2013 08:27 AM
metalmechanix
Dec 25, 2004 05:24 PM
Dalamatition
May 12, 2004 07:31 AM
Fordnite302
Mar 10, 2003 05:45 PM
