Starter stays engaged
Old Jul 11, 2022 | 11:43 AM
BayouBilly34's Avatar
BayouBilly34
4wd High
Originally Posted by Sous
If I were you, before I invested any further money or time I would go with the advice from kbeefy in post #3.
A second electrical shop traced it back to the fuse block after the GEM was replaced. Hopefully they’re correct this time
Old Jul 15, 2022 | 05:01 PM
BayouBilly34
4wd High
Somewhere along the way after opening and cleaning the fuse box and replacing the GEM, the starter is now disengaging. But now it won’t key start. It will only start by jumping the fender mounted solenoid. As soon as the key is in the accessory position, the solenoid constantly clicks. I’m about at my wits end here.
Old Jul 23, 2022 | 07:09 PM
BayouBilly34
4wd High
FIXED
Went back and looked at the starting wiring diagram. Everything was in order. Got to thinking maybe it was cheap Oreilleys parts. Ordered and installed Motorcraft starter solenoid and ignition switch. Starts like new with they key. Lesson learned, wait on quality motorcraft parts to be delivered before going with aftermarket junk. Thank you all for the responses as I have a better understanding of the starting system if I have a future issue.
Mark Twain
Jul 30, 2023 10:46 PM
halfrhovsquared
Jul 17, 2021 09:05 AM
Dunndeal
Jul 26, 2018 08:39 PM
brookdale79
Jan 18, 2015 03:26 PM
