another squealing brake thread
Old May 3, 2022 | 07:21 AM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Thank you sir
Old May 3, 2022 | 04:22 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Ok, brake lube ordered along with an IR gun. Hopefully I can get this thing to shut the hell up!
Old May 7, 2022 | 02:36 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Ok, lubed the snot outta everything. Stretched the v springs a little more. Found a loose clip and fixed that (hopefully that was the problem). Going on a drive this evening to see if its fixed.
Old May 7, 2022 | 03:02 PM
SkySkiJason's Avatar
SkySkiJason
How old are the unit bearings? Have they been filled with grease?
Old May 7, 2022 | 03:11 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
brand new timkens with less that 400 miles on them. Both filled with mobil1 synthetic grease through the abs hole with riffraff adapter.
Old May 7, 2022 | 03:42 PM
SkySkiJason
I expected as much.
Definitely a head scratcher... I’ll be giving this more thought.
Old May 7, 2022 | 08:03 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
Brakes still squeak while turning right
Placing an order with ssbc me thinks.
Old May 7, 2022 | 08:16 PM
FordTruckNoob's Avatar
FordTruckNoob
Well crap on the continued squealing, but yay on the SSBCs!
Old May 7, 2022 | 09:30 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
SSBC brakes are quite nice.
Strange the squeak is still there...
Old May 7, 2022 | 09:43 PM
BWST's Avatar
BWST
Got Data?
Have you performed a pad bedding procedure? If you have, maybe do a couple more, with a cool down period in between.
Since everything is new, consider swapping left front and right front pads and bedding them again.
Are you sure it's the front brakes? Just spit-balling.
Old May 8, 2022 | 12:39 AM
F0rdc0wb0y's Avatar
F0rdc0wb0y
no sir, I never bedded the pads. Just before I bought the truck, the previous owner installed new ford calipers and pads on all four corners. During my front end rebuild I installed new ford rotors as the ones that came on the truck were garbage. I then reinstalled the newish calipers and pads. It was good for a while and then developed this squeak within the last week or so. I really don’t wanna spend $1300 to get rid of a squeak.
I just hit both front rotors with my IR gun . They are within a degree of each other. I don’t think they are hanging up. I have absolutely no idea. Maybe new pads?
Old May 8, 2022 | 07:00 AM
FordTruckNoob
I second what Jeff said about rebedding the pads. The procedure is attached.
File Type: pdf
Old May 17, 2022 | 05:56 PM
  #28
F0rdc0wb0y's Avatar
F0rdc0wb0y
New hawk lts pads properly bedded…still squeaks when turning right
Old May 17, 2022 | 08:27 PM
  #29
FordTruckNoob
Well this one’s a head-scratcher. Take a video?
Old May 18, 2022 | 02:41 PM
  #30
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I seem to recall the Hawk pad bedding procedure was different in the past.
Current:
1. To break in the new components, make 6 to 10 stops from approximately 30 to 35 MPH applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approximately 40 to 45 MPH.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
5. Your brakes are now ready for use and can be driven normally.
That's a lot of stops. IIRC the old advice was moderately aggressive braking 3 or 5 times from 60ish to 20ish to get them hot, but never come to a stop. Stopping allows transfer of pad material to the rotor and is to be strongly avoided. After getting them hot just keep driving for 10 minutes to cool them off before coming to a stop.
Anybody else recall that?
