abs light
Old Nov 8, 2003 | 10:09 AM
mike2002's Avatar
mike2002
abs light
I have a 1998 ranger 2wd with rear abd my light comes on once in a while. I replaced the rear brakes and hardware, any advice what to check next would be appreciated
Old Nov 8, 2003 | 11:06 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I had this problem once, usually occuring after hitting the brakes hard. It went away after I totally flushed out the brake system with new fluid.
Old Nov 8, 2003 | 08:17 PM
Dealford's Avatar
Dealford
Welcome to FTE mike2002. The ABS sensor is on the top of the differential "pumpkin". Check that it is not oil-soaked and otherwise dry inside. Follow the lead back to the chassis to make sure that it hasn't been rubbing anywhere causing it to ground out. Make sure that the rear brake adjusters are working properly and not allowing the rears to be too far out of adjustment.
Old Nov 9, 2003 | 08:23 PM
Ken00's Avatar
Ken00
Check out the tech info post for pulling the RABS code.
Old Nov 11, 2003 | 06:04 PM
johnwelcome's Avatar
johnwelcome
abs light
had the same problem last year. noticed brake fluid was low and all I did was top it off. Its been a year and no light since.
abyars111
Nov 12, 2012 09:18 AM
hamiltonfighter
Jul 14, 2012 09:52 PM
blackford97
Sep 5, 2011 10:28 PM
bsteam
Apr 29, 2010 11:45 PM
DieselOwnerNow
Mar 31, 2008 01:19 AM
