Weird issue starting
Old Apr 25, 2022 | 02:34 PM
Tctrucking's Avatar
Tctrucking
94 f240 psd manual 4x4 if i switch key on and wait for wts light to go off it starts fine but cel is on....
if i just jump in turn the key DO NOT WAIT for wts light to go off it still starts but will do a rough idle then clear up and the cel DOES NOT COME ON
only things ive done to truck intake, down pipe, ebvp delete, and ts 6 position chip
any ideas or nothing to worry about??
Old Apr 25, 2022 | 07:54 PM
Edgethis's Avatar
Edgethis
Have you tried reading the codes to see what's causing the light to come on?
Old Apr 26, 2022 | 03:17 PM
Tctrucking's Avatar
Tctrucking
no i need to find a way to read them the plug under dash on passager side of dash wont read anything.....
Old Apr 26, 2022 | 05:37 PM
96 OBS's Avatar
96 OBS
Only a select few scanners can read these trucks. Forscan being the most common one. You just need a cheap Bluetooth obd connector and the app
Old Apr 26, 2022 | 05:48 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
...and being an early truck means you may not be OBD2 compliant, just OBD2 ready. If you have a chip of any sort, this puts the latest factory flash on the PCM.
Old Apr 27, 2022 | 07:37 PM
timrothschild1's Avatar
timrothschild1
If you did not buy the dead end connector when you did ebpv delete you will get cel. Call Clay at Riff Raff and tell him you did the delete and you need the plug to keep light off
Old Apr 28, 2022 | 09:16 AM
Leatherneck007's Avatar
Leatherneck007
yes, what Tim said is right. get the dead end connector from Riffraff diesel.
mike71800b
26
Jan 23, 2019 11:52 AM
Psyclopse
Mar 8, 2018 09:16 AM
Whitey Ford
Jul 9, 2010 06:35 AM
adamant
Aug 19, 2003 10:25 PM
jdt815
Electrical Systems/Wiring
Aug 19, 2003 09:07 PM
