EGR crap...p0401
Old Apr 21, 2022 | 03:12 PM
Tony Ricci's Avatar
Tony Ricci
EGR crap...p0401
Ok..we all know what this is about....I've taken the EGR valve off and cleaned it...checked the port...seems clear...a new sensor....I've tried to make sure lines r clear...no vacuum leaks that I can find...any suggestions would be sweet.....should I do a new egr because it's bad even after cleaning? Help...I've got till end of month....oh yes...I'm in California.....I know I know
Tony Ricci's Avatar
Tony Ricci
Sorry....96 f250 7.5l
Old Apr 21, 2022 | 03:32 PM
james_1988f250's Avatar
james_1988f250
I feel your pain. I didn't get my emissions fixed in time my registration was for March so I can't even drive right now. I tried cleaning out my EGR months back because its such a pain to get off and it clearly didn't help. Check the solenoid on the top of the valve for electrical but you probably just needed the new valve.
Old Apr 21, 2022 | 07:44 PM
Tony Ricci's Avatar
Tony Ricci
More then likely....at a cost of 251.00......plus the 300 I had to pay to register then beast....thanks cali****infornia......*******s
Old Apr 22, 2022 | 06:48 AM
rla2005's Avatar
rla2005
How To Test The Ford EGR Valve, EGR Vacuum Solenoid, DPFE Sensor
Old Apr 22, 2022 | 01:37 PM
james_1988f250
251.00???? Where did you find an EGR valve for that much? I picked up a Delphi one for 80 bucks on summit
Old Apr 22, 2022 | 01:48 PM
rla2005's Avatar
rla2005
Since the OP is posting a P0401 error that means their truck is OBD-II. Those trucks use a different EGR valve than the OBD-I trucks. Less of them out there so the price goes up accordingly. Error P0401 indicates the EGR gas flow is too low. That signal is derived from two sample tubes in the EGR tube itself. Those two tubes are connected to the DPFE sensor via silicone hoses. If the DPFE sensor tests good then the next step is checking the silicone hoses for cracks. If those are good the next area to look is the EGR tube itself. Could be cracked or the sample tubes are plugged.
Old Apr 22, 2022 | 03:05 PM
AuroraGirl's Avatar
AuroraGirl
you have an OBD2 7.5 :O
Can I see a picture of your engine
Old Apr 22, 2022 | 10:03 PM
Tony Ricci's Avatar
Tony Ricci
Rla....that could be it because as while back I had to replace the exhaust manifold on that side ..could have done it thenqq1
AlewisIII
Jan 19, 2022 12:35 PM
mat-it
Jan 2, 2021 10:41 PM
BRONC-OH
1997 - 2003 F150
Jun 12, 2016 01:53 PM
Thedonk
Jun 4, 2016 08:03 AM
My Good 'ol 92
Aug 14, 2011 12:10 PM
