Pimpx + EGR
Old Jan 2, 2021 | 05:43 PM
mat-it's Avatar
mat-it
Pimpx + EGR
When installing the Pimpx ECU, does anybody retain the EGR? Or do you have to delete it.
Old Jan 2, 2021 | 06:37 PM
EllieMae94's Avatar
EllieMae94
The EGR/EVP is not used with the pimp computers. If you really want to retain it I’m sure it can be done though.
Old Jan 2, 2021 | 06:39 PM
EllieMae94's Avatar
EllieMae94
To add to that, you don’t have to physically remove any of the EGR components. You can keep the valve, pipes, vacuum hose, etc installed. It just won’t be functional.
Old Jan 2, 2021 | 08:16 PM
mat-it's Avatar
mat-it
OK. It’s not that I wanted to put the effort in to make it work, just thought it if it was easy I’d hook it up.
Old Jan 2, 2021 | 10:41 PM
EllieMae94's Avatar
EllieMae94
Yeah you could hook it up without too much effort. Just keep in mind you only have two spare analog inputs, more if you have the expansion harness. Mine are both being used for pressure sensors; one for fuel, the other oil.
olfordsnstone
Aug 20, 2013 11:14 PM
the_sharkster
Mar 7, 2007 02:04 PM
