Egr.
Old Jan 18, 2022 | 06:19 PM
AlewisIII's Avatar
AlewisIII
Egr.
Got an egr question. If I disconnect the green vacuum line going the egr and apply vacuum to the egr diaphragm should it hold vacuum and not bleed down?
Old Jan 18, 2022 | 06:50 PM
torq'ta 5 8's Avatar
torq'ta 5 8
yes, it should
Old Jan 19, 2022 | 06:22 AM
AlewisIII's Avatar
AlewisIII
Ok, thanks
Old Jan 19, 2022 | 06:49 AM
AlewisIII's Avatar
AlewisIII
Also I checked the egr solonoid on top the egr and the resistance was 3.49. Is that in range ?
Old Jan 19, 2022 | 07:07 AM
torq'ta 5 8
Depends which one you have, Lt. Grey, or Black
Ford Fuel Injection » EGR Valve Position sensor (EVP)
Old Jan 19, 2022 | 08:48 AM
rla2005's Avatar
rla2005
Closed EGR valve EVP resistance should be ~5500 ohms measuring between the EVP output and Signal return pins. Fully opened EGR EVP resistance should be ~100 ohms. This assumes you have the correct gray EVP sensor installed.
Old Jan 19, 2022 | 09:34 AM
AlewisIII's Avatar
AlewisIII
Hey thanks for the info, one other question my truck runs pretty good in park but in drive with foot on brake has a slight miss and battery voltage needle jumping back and a little.
Old Jan 19, 2022 | 09:43 AM
rla2005's Avatar
rla2005
Worn spark plugs/wires/Cap/rotor can cause a miss under load. Not routing the plug wires properly to prevent cross fire is another common cause of a misfire. Also using the wrong firing order can cause a misfire. Many other causes that you need to investigate if the ignition components are verified good. If you have a 2G alternator it puts out very little current at idle. It is a design flaw as well as the very common melting power plug that catches fire.
Old Jan 19, 2022 | 10:10 AM
rla2005's Avatar
rla2005
Correct firing order and spark plug wire routing diagram (courtesy of Steve83) for 1994 and up 5L engines and all 5.8L engines
Old Jan 19, 2022 | 12:35 PM
AlewisIII's Avatar
AlewisIII
Hey thanks, appreciate the info
BRONC-OH
1997 - 2003 F150
Jun 12, 2016 01:53 PM
azazel_18_2
1997 - 2003 F150
19
Nov 1, 2007 02:49 PM
DOHC330MustangGT
13
Jul 8, 2005 02:48 PM
Boomer95
Jan 15, 2002 07:10 PM
fordsrus
Oct 30, 2000 07:23 PM
