Windshield washer fluid just stopped.
Old Apr 21, 2022 | 11:03 AM
Brian Hanks's Avatar
Brian Hanks
Windshield washer fluid just stopped. Yes it’s full. I don’t hear the motor running. How do I troubleshoot this? I may have missed it in the tech folder.
what Fuse..? Obviously it could be the motor itself. Or the switch. I absolutely suck at electrical anything so the five year old explanation is probably about right for me 😆
Old Apr 21, 2022 | 12:14 PM
udsuth78's Avatar
udsuth78
Pretty sure it's listed in the owners manual, but I'll double check...
Yep page 127 lists it as fuse 11 10 amp in interior panel. Then page 131 has the relay in 33 hole of exterior panel. If yours is a later model with only one power distribution panel then I suggest your owner's manual.
Old Apr 21, 2022 | 12:15 PM
Brian Hanks
Ha. Thanks
Old Apr 21, 2022 | 05:49 PM
Wes444's Avatar
Wes444
Was that the fix? If not there is a pump screen that can get clogged from debris
Old Apr 21, 2022 | 08:32 PM
uglypitbull's Avatar
uglypitbull
I had to replace the pump in mine last summer....its below the fluid reservoir.
Old Apr 21, 2022 | 10:28 PM
Brian Hanks
Yes. Fuse fixed it. 👍🏻. Had to go into work just as it went out and I posted. Hopefully nothing is bad that causes to blow again… 🤔
thanks
Old Apr 22, 2022 | 06:38 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Easy fix!
If the fuse blows again, you will need to "absolutely suck" less on electrical stuff and use a multimeter most likely. Maybe you will get lucky though and this is a good start to a great weekend.
Old Apr 22, 2022 | 11:28 PM
Brian Hanks
Originally Posted by Sous
Easy fix!
yeah. I don’t know why but my brain has had to grasp some seriously complex stuff in my life but a multimeter and I’m 5 years old again. Literally have to play a you tube video with exactly what I’m working on and pause and watch and repeat whilst doing the activity to get it right. The overhead console short I found was a minor miracle. But that maybe because I hadn’t broken out the multimeter yet lol.
had trouble all my life conceptualizing it, yet I can “see” neuro anatomy and all the flow of “electrical” current that drives that NO problem.
man’s gotta know his limitations… I usually hand electrical stuff to the wife. She is legit good at it. I’ll repave the driveway while she is working on it…
phoneman91
Feb 21, 2009 06:07 AM
995.4SD
Sep 14, 2008 03:40 PM
saipan
General Automotive Discussion
Jul 31, 2005 06:37 PM
Pathfinder1369
1983 - 2012 Ranger & B-Series
Jul 27, 2004 04:38 PM
