Sponsored by: Real Truck
Help with windshield washer fluid???
Old Sep 12, 2008 | 08:50 PM
995.4SD's Avatar
995.4SD
My pasher fluid has never worked my truck since i bought it...wipers work great but not fluid. i replaced the motor on the bottom of the tank, and still nothing. what else is there to go wrong?
Old Sep 12, 2008 | 11:03 PM
ReAX's Avatar
ReAX
First check that the motor receives power when the stalk is pressed. If it doesn't then it's time to move upstream. You could check all of the fuses or just check the stalk.
Old Sep 14, 2008 | 10:55 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
I've had the squirters clog with wax and just about dribble out. Cleaned the holes with a safety pin. HTH
Old Sep 14, 2008 | 11:41 AM
F350-6's Avatar
F350-6
Can you hear the motor run when you push the switch? That should tell you if you need to chase electrical, or look for an obstruction.
Old Sep 14, 2008 | 02:25 PM
995.4SD's Avatar
995.4SD
I can't hear anything when i push in the button, so i don't think it is getting power. fuses all checked good. once it stops raining i will check for any loose connections. thanks for the help guys.
oh by the way i think the nozzles are clear but will double check them too.
Old Sep 14, 2008 | 03:25 PM
BareBones's Avatar
BareBones
What does anyone think about applying 12v directly to the washer motor?
Old Sep 14, 2008 | 03:40 PM
ReAX's Avatar
ReAX
That should make it spin. You wouldn't need very big wire, it should draw minimal amps, but I would unplug the harness the harness first.
