We have a 2016 F250 with the 6.2 L v 8 engine. We tow an 11,000 LB GVW 5th wheel trailer. We tend to average high 7’s to low 8’s in mpg. We’re looking at downsizing to a bumper pull that has a 6,800 LB gvw and is nearly a foot lower in overall height.
Any thoughts on how much if any improvement I may see in mpg?
I’d say a big obstacle is merely the huge flat front of the camper being pulled into the wind… Just guessing on my part, but I don’t know if you would see much of an improvement, if any.
Truck stance, tire size, gearing, engine, transmission gearing, trailer height, trailer profile, roads you drive on, and how you drive, these and more must be taken into consideration.
Your biggest problem other than the above is the application of the skinny pedal and planing ahead while in motion as well as getting into motion.
We have played leapfrog with trucks and campers a bit. At one time, I had a tiny 17' hybrid RV that barely weighed 3500lbs and towed it with an F150 5.0L. It got 10mpg. That same truck got 10mpg with our current trailer which is twice the size. I agree with the other poster that wind drag across the face of the camper will automatically bring you into an 8-11mpg range, and then total weight and truck setup may affect that up or down 1-2mpg from there. When we realized that any trailer is going to put us in basically the same MPG range we decided to upgrade to a larger unit for more comfort. Of course that unit ended up being a bit too much for the F150 and here we stand with the F250, but we are very happy with this setup. Well within the limits of the truck and very comfortable at camp.
I've come to expect 9mpg but generally hit 10mpg and tell myself to be happy about it.
I generally agree with the others. I'll guess that you'll see maaaaybe a 1MPG improvement if you mostly tow in flat areas for long distances at highway speeds. I'll also guess that you'll see 1 or maybe 2 MPG improvement if you tow short distances, in lots of stop and go, and/or if you tow in hilly areas. These are apples to apples guesses as in same conditions, behavior, etc. with the only difference being the trailer.
I'll be interested to see what your experience actually is.
I'd guess you'll be in the same general range, maybe 8's. Bumper pulls are like attaching a sail to the back of the truck where as 5th wheels tend to be more aerodynamic. A lot of slow speed, back road driving, you might notice an improvement just from the reduction in weight but, at speed, worse aerodynamics take a lot of power to overcome, sucking up any efficiency gained by the reduced weight.
we have a 11' 8" tall 34ft long 9500 gvw travel trailer. last time i scaled it we were about 16,500 combined. i get 8-9 mpg on my normal tune depending on terrain. i get 5-6 with E85. my truck is also lifted on 35s and has 4.88 gears. i dont go faster then 65 cause i dont trust the current tires, they will be replaced this summer, and mpg drops quicker at higher speed.
I purchased the 2017 SD 6.2 this fall in anticipation of our new 28BH Vibe Travel Trailer. Max weight is 9,730 and we are taking it from Maryland to Bar Harbor this August. We booked the trip before gas was $4.25 but I am expecting 8-9 MPG. I am really surprise that my truck gets 11.2 daily without a load, stock. Seems low. Have not pulled the camper any farther than from the dealer so I dont have numbers yet.
I'm curious what MPG you get. At the same time, I think 8-9MPG might be optimistic.
I have had 2 RV trailers on my current truck. Our first trailer and our current trailer. The first trailer was like 9.5 or 10 feet high. No room inside 30 footer weighing 6,000 pounds wet. I usually got around 9 MPG. The current trailer is 11 foot high weighs 9500 wet. 36 footer. Average MPG is around 8 to 8.5. Depends on the terrain as did our old one. More of an interesting note, our current trailer is easier to tow. Probably due to the better design of the trailer. There were not as many pucker moments on the road with it.
Based on my experience with the 6.2L/4.30 gears and ~8500 loaded 11' 6" high trailer 8-9 is a pretty reasonable estimate. I just finished up a ~2300 mile round trip from the Seattle area to Las Vegas. My overall hand-calculated MPG was 8.3 with a couple of tanks in the ~6.6 range due to stiff headwinds and a tank at ~9.92 through central Idaho with a little tail wind. The majority of tanks fall within the 8-9 range. This trip included several mountain passes as well as relatively level stretches and I generally run around 60-62 mph. I have the 34g tank and usually plan for a fuel stop every 220-240 miles. I do have a Leer Hi-Rise canopy on the truck and based on my unscientific analysis of mileage along the same route before and after having that installed it does seem to have made a slight improvement. It definitely makes the front cap easier to clean by pushing the bug line up quite a ways. Unloaded I average ~11-12 all city and ~15-16 all highway though I have seen as high as 16.8 on one unloaded highway tank.
This thread is a bit reassuring in that we are getting about the same as everyone else. Our travel trailer is 7,500 loaded, 30' long and about 11' tall. Towing on the highway, I run a constant 65mph flat ground, uphill and downhill. Hand calculated, it averages right about 7.5-8 mpg. All of my estimates for fuel on trips is is based on 7.5 mpg and its been pretty dang close.
In June, we leave the Seattle area for Yellowstone. The trip will be about 1,750 miles towing. With fuel prices the way they are, we are going to experiment with running at 60mph to see if we gain any improvement. I'm not expecting a miracle but picking up any fuel economy should be worth the extra little bit of time on the road.
One thing that I'm also curious in is how the topper will affect fuel economy, if at all. We've always towed with a tonneau cover on the bed. This last year we added a Leer, cab height topper. My hopes are that it helps the truck and trailer be more streamlined but with the added weight of the topper, it likely will zero out. Either way, more secure bed space is well worth it.
