I do not believe there is a dipstick tube on manual transmissions.
Correct, there is no dipstick tube. I'm honestly not sure I've ever seen *any* Manual transmission with a dipstick. I'm sure that they've got to exist, but I've never seen one.
Thanks for the clarification I didn't read in enough to see that the TS had a manual because he said torque converter lol. Yes if you have a manual transmission and shifting issues its likely forks. If you have an automatic probably low fluid level
It shifts fine it’s just a weird noise like somethings spinning on something. When backing out it just dies like a stall out then no start for a while then starts back up.
it’s a t18 4speed if I’m not mistaken
also isn’t there a way to get codes off this truck
