82 F350, T18, 351W. If I hit the accelerator hard I hear a noise from my engine, like a clicking/tapping. It is very faint. If I ease up, it disappears. Is this pinging? If so, do I just retard my timing a little to cure it? That means that if I use 10 degrees BTDC now, I want to go to a lower number to retard it? Correct?
It could be pinging.....which will occur under load & then stop when the load is reduced, but so does knocking from a mechanical fault. Pinging sounds different in different engines - from a hard tapping to a light, metallic tinkling.
Turning the distributor counter-clockwise (viewed from above) will retard your timing & stop the noise. But pinging can have many causes....so if your compression & timing etc, are near spec, something else could be at play.
If you want to verify if it's the timing, take the hose going to the distributor off and plug it, and see if it goes away. If it does, it probably is a pinging/timing issue.
I have been down this road before. You can turn the timing back, but the more you turn it back, the less power and throttle response the engine has, and the less fuel mileage you get. You can try to leave the timing where it is and try to get the EGR working again. The EGR will help with pinging. But if you have modified the exhaust like I had (headers and duals) then it's difficult to get the EGR to work correctly also.
What finally made my pinging go away was to change to a 180 degree thermostat. Mine would not ping running around town, only would do it after a hard run on the interstate.
But take the line off the dist first to verify it is a timing issue.
YES! Tinkling is the best description. Thank you. I will try the timing change.
Thank you Dave F, I will try to plug the distributor line and see what happens. Exhaust is stock. I suppose this could eventually destroy the engine?
Could be. but I doubt it’s a timing issue. You may be hearing valve train noise from dirty or weak lifters. Todays fuel causes a lot of vapor lock issues with carburetored vehicles today. You can address all of these problems and fix them. I would start with running your tank down and try a quarter tank of non ethanol or at the least 89 octane just to see if that changes the noise. I would also add a quart of Rislone engine treatment. It works great for cleaning and eliminating lifter chatter. Lifters often need replaced on older vehicles. They are very easy to replace. Try cleaning them first with Rislone added to oil. A quart of diesel fuel added to oil works just as well. Let it idle for a few minutes, drain. Last resort before buying new ones is to disassemble lifters and clean by hand. Often works. Sometimes it doesn’t. If it doesn’t, replace them if you verify that’s what the chatter is. All easy to address.
Assuming it is pinging, it sounds light......but IMO still needs to be corrected. The owners manuals say some ping is acceptable, but personally I would tune it completely out, to be safe.
