Timing Information
Old Mar 29, 2022 | 11:12 AM
FordTrucksChris's Avatar
FordTrucksChris
Timing Information
I was setting the timing on the truck and noticed what I think is a pinging noise. Looking for validation
File Type: mp4
Old Mar 29, 2022 | 03:56 PM
FuzzFace2's Avatar
FuzzFace2
The only time you will hear pining or spark knock is when driving and the motor is under load.
Most of the time it is low RPM and a load like going up a steep hill but if really bad can happen going down the high way under a light load.
What I hear sounds like a EXH. leak at idle.
What did you set the timing to and was the vacuum hose off and plugged?
What was the idle RPM when you did it?
Dave ----
Old Mar 29, 2022 | 09:46 PM
FordTrucksChris
Dave ----
I realized I did it without the hose off and plugged. I had it right at TDC. I don't have a tach unfortunately so I don't know the exact idle
Old Mar 30, 2022 | 09:35 AM
FuzzFace2's Avatar
FuzzFace2
Hose off and bump it up to 8 to 10 BTDC
Dave ----
Old Apr 3, 2022 | 03:59 AM
Ozzie H.'s Avatar
Ozzie H.
That may not be pinging. To me it sounds like something in one of the valve trains.
Kev1180
Large Truck
Sep 2, 2015 03:56 PM
topfisherman
1978 - 1996 Big Bronco
Mar 23, 2004 08:29 PM
