2004 6.0 no reverse
Old Apr 7, 2022 | 11:53 AM
BWilcox's Avatar
BWilcox
2004 6.0 no reverse
Hey guys, I have a f-350 2004 6.0 with a automatic transmission. I was driving it a while ago and the tow/haul button started blinking so I knew there was something wrong with the tranny. It drove home fine and when I got home I went to put it in reverse and it drove forward. I put it in neutral and it drove forward. All gears except park and it drives forward and in drive it still shifts a little off. The tranny fluid was a little dark so I changed it but it didn’t fix anything. Does this sound like a sensor or solenoid going bad or staying stuck open? Or did I loose reverse and the tranny is shot? Any help is greatly appreciated, thank you.
Old Apr 7, 2022 | 10:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Your forward clutch has failed and is welded together. It is time to rebuild or replace the transmission.
Old Apr 8, 2022 | 10:26 AM
BWilcox's Avatar
BWilcox
@Mark Kovalsky would a regular tranny rebuild kit including this or would I have to get something special?
Old Apr 8, 2022 | 01:04 PM
Mark Kovalsky
That depends on what's damaged. If damage is minimal, a master rebuild kit will have what you need. If it is extensive, you will need to replace hard parts that are not part of any rebuild kit. The only way to know is to tear it down and inspect it.
jle70
Oct 10, 2015 10:47 AM
Michael Griffin
Mar 4, 2013 08:42 AM
91 blowncoupe
2004 - 2008 F150
Dec 27, 2008 10:04 PM
nymets78
Aug 8, 2005 08:46 AM
