2004 - Transmission
Old Aug 7, 2005 | 09:05 AM
nymets78's Avatar
nymets78
2004 - Transmission
I had a rather strange occurrence that so far, has only happened once but I am still concerned. Several months ago, I had the addive added to the tranny fluid to prevent the harsh reverse engagement. That has worked very well. However, last night I pulled into a friends driveway to turn around, backed down the driveway (reverse engagement was smooth), got into the street and switched into drive. Nothing harsh about it until I started to press the gas and found NOTHING happening for a few seconds. I looked to be sure it wasn't in neutral, which it wasn't and then, all of a sudden a bang and it started to go forward. Has anyone had something similar where it doesn't switch to drive right away?
Old Aug 8, 2005 | 12:17 AM
aquanaut20's Avatar
aquanaut20
yes, and I changes the pressure regulater valve to fix it..... but see if it has set any codes first....
Old Aug 8, 2005 | 08:46 AM
edward r's Avatar
edward r
what additive are you referring to to smoothen out the shift into reverse ?
54racer
Feb 6, 2010 08:45 PM
rogarl
Oct 31, 2005 08:48 AM
houstonwinrock
Aug 24, 2005 07:02 PM
Sock Monkey
Jun 19, 2005 08:54 PM
