Help wth VIN
Old Apr 5, 2022 | 06:25 PM
ejanzen6700's Avatar
ejanzen6700
4th Gear
Help wth VIN
Hello all,
I have a 59 F-250 and am trying to figure out the VIN. The plate is not on the drivers door nor on the glove box, but I found the 2 stamped on the frame. I have attached pictures because it seems like there may be something missing at the front of the VIN. there is a space between the number 4 and the 25 on both VINs. Should there be something there?
Old Apr 5, 2022 | 07:39 PM
spurredon's Avatar
spurredon
Welcome to FTE. Kind of unique with the blank spots. I would expect to see an F before the 25 and then either a J,K or L prior to the 8. The 8 makes me think it is a '58. Not sure about the Y. The K would indicate the Kansas city plant and the remaining numbers are the sequence of Assembly. The trucks specific serial number. fortunately there are many folks here smarter than I who might know. how about a pic of the beast?
Old Apr 7, 2022 | 09:29 AM
ejanzen6700
4th Gear
Here is a pic in current state. It is getting IFS and IRS and a crown vic drivetrain.
Old Apr 7, 2022 | 10:53 PM
Archie’s Beater's Avatar
Archie’s Beater
that picture looks very familiar..
I’m also jumping into the cv ifs and mustang irs rabbit hole. This is how far I got last weekend. Old suspension out and resting(not mounted) on the new setup. Trying to decide on ride height. Still undecided on engine and drivetrain, but I’ve got plenty to do first. Are you boxing the frame? Front to back?
Old Jun 29, 2022 | 09:33 AM
Bogus1251's Avatar
Bogus1251
Trailering
Canadian vin plate (missing)
Hello,
Did you have decode your no. on the frame...
Your number
4= Ford 8 Cyl.
3 blank !!! i supposed 99
99= flush side
25= f-250
18= whellbase 118
YK= (Y= 1959 ), (K= Okville Ont.)
55277 sequence number
I have too a 59 pick-up and i can't find my number on the frame!!
Can you tell me exactly where this number is located
Thank
Old Jul 12, 2022 | 11:37 AM
ejanzen6700
4th Gear
ne on the drivers side near the crossme,ber mount and on on th passenger side under the cab. (Luckily my cab is not attached)
Old Jul 13, 2022 | 08:28 AM
Bogus1251's Avatar
Bogus1251
Trailering
OK thanks you
mmason710
Large Truck
Mar 28, 2025 11:15 AM
jcjc123
Apr 21, 2021 11:27 AM
Trela Wishon
Large Truck
Mar 1, 2021 11:31 PM
Gary38532
Dec 3, 2017 08:24 PM
Meylan
May 12, 2016 04:26 AM
