Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 VIN Help
Old Feb 3, 2022 | 09:25 AM
mmason710's Avatar
mmason710
F600 VIN Help
Hi all,
I was looking to see if somebody could help me identify the year of a truck I recently acquired based on the production sequence number of the VIN. Everything I have found seems to indicate that it's a 1972 but I wanted to check with those who have a better knowledge of the production numbers than I do.
VIN: F60DV060112
TIA
Old Feb 3, 2022 | 09:56 AM
85e150's Avatar
85e150
Welcome to FTE !
I will decode this later today.
Old Feb 3, 2022 | 01:21 PM
85e150's Avatar
85e150
F60 = F600 gas, 4x2
D = 330 2V XD gas FT V8 (XD replacing HD)
V = Kentucky Truck Plant
060112 = 1977 numerical series (1972 uses the letter "o" vs. zero, and they look the same in print. Best I can tell. See model number below)
158 = 158 inch wheelbase
T = Red
F602 = F600 gas, 4x2, 19,200 lbs GVWR (For 1972, model F602 shows the same except a 20,000 lb GVWR)
AA8 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process model 435 four speed transmission
F2K
F2 = Eaton model 15201 two speed rear axle, 15,000 lbs capacity, 5.83/8.12 ratios
K = Ford 5,500 lb capacity front axle with power steering
19200 = 19,200 lbs GVWR
25 = Richmond District Code
No special order
Let me know if something doesn't line up. Beware widowmaker wheels! Post more pictures if you want and good luck with it!
Old Mar 22, 2025 | 06:24 PM
Ethan Hubbard's Avatar
Ethan Hubbard
2nd Gear
Sadly. I just saw this truck at a junkyard here in Virginia. All the numbers on that plate matched the ones on the truck. 😭
Old Mar 28, 2025 | 11:15 AM
Ethan Hubbard
2nd Gear
Originally Posted by mmason710
Hi all,
VIN: F60DV060112
TIA
Found it again. Sadly in it's finally resting place.
Jayson Mark
Large Truck
Jul 14, 2020 05:07 PM
Meylan
May 12, 2016 04:26 AM
sspencer
Large Truck
Jun 14, 2015 10:36 AM
Ivan M.
Feb 6, 2009 05:20 PM
