Sponsored by: Real Truck
Steering issues (redhead gearbox?)
Old Jun 23, 2010 | 09:34 PM
cc322's Avatar
cc322
Seems like i have been fighting a steering wandering problem for a while now, and cant seem to find anything to make my truck steer without so much driver input, makes for a unrelaxing drive on long trips cant relax behind the wheel. My truck is at a suspension shop right now and he cant find anything wrong with it. He says may be coming from the gearbox. My question is the redhead gearbox any good, who has one and what is your opinion. Yes i have done a search but not alot of info to be found. And he also says all suspension parts are tight and not worn.
Old Jun 24, 2010 | 09:09 AM
jlalanas's Avatar
jlalanas
The shop I use for alignment, etc recommended that I increase the tension on the steering gear. Not sure exactly how this is done, but apparently the ford spec results in a bit of "play" in the steering wheel. So I had them go ahead and increase the tension and it took a little play out of the wheel. From what I remember, you have to be careful not to over-tighten because it may cause the steering to bind at full lock, or something like that.
Old Jun 24, 2010 | 01:49 PM
SteveH-CO's Avatar
SteveH-CO
Adjusting the steering box:
Have an assistant (wife) slowly rock the steering wheel back and forth while you watch the input shaft and pitman arm on the steering box. Listen for any knocking sound, too. If there is visible play (defined here as a lack of pitman arm movement for a given amount of steering shaft input), then adjust as follows:
Loosen the locknut on the top of the steering gearbox and then turn the allen-head screw about 1/8 of a turn to the right, and retighten the locknut. Drive the truck - if the steering seems stiff at all, then undo the adjustment you just did. I found that 1/4 turn was too much. Since steering boxes wear in the 'middle' (where you drive 95% of the time), if you get them too tight, they will be ok in the middle, but will bind under a full-lock turn. So, don't go overboard with the adjustment.
Adjusting the box won't solve all box-related sloppiness, but it will sure take the edge off the slack in the steering.
HTH,
Steve
Old Jun 24, 2010 | 06:36 PM
cc322's Avatar
cc322
Thanks but have allready done that!
Old Jun 24, 2010 | 08:46 PM
Monster-4's Avatar
Monster-4
After replacing pretty much every component in the front end I installed a Red Head and love it.
https://www.ford-trucks.com/forums/8...installed.html
Corpsman24
Jul 30, 2015 06:42 AM
rwrogers
Ford Truck Parts for Sale
Jun 18, 2015 12:59 PM
AKHunter93
16
Jun 1, 2015 11:56 AM
Golden Helmet
Jul 22, 2014 10:08 PM
jgavac
Mar 3, 2014 01:16 AM
