Increased Compression 400m
Old Apr 2, 2022 | 05:53 PM
1979-F150-400m's Avatar
1979-F150-400m
Hello,
I have a 1979 F150 Supercab with a 400m motor, and I'm looking to increase the factory compression without emptying my wallet. Ive read that the 400m's have negative deck high, so I want to do something that will raise the piston at top dead center. Ive been thinking about either longer connecting rods, or taller pistons. Does anyone have suggestions for parts? Ive seen some thing that 351m pistons could be used, but have a smaller wrist pin. Could I then use 351 Rods? Just thinking out loud so to say, what do other people think?
Thank you in Advance!
Old Apr 2, 2022 | 05:55 PM
ivsamhain's Avatar
ivsamhain
Tmeyer and Dss have off the shelf pistons at correct pin height. 1.710 for zero deck.
351c pistons have a different size pin and still an incorrect height for zero deck. 351m have the same pin size, it’s a destroked 400.
351m rods are the same. 351c rods won’t fit the crank.
Old Apr 2, 2022 | 06:13 PM
5851a's Avatar
5851a
TMeyer has pistons for zero deck I believe.
Old Apr 2, 2022 | 06:45 PM
6 by 8's Avatar
6 by 8
Originally Posted by 1979-F150-400m
Ive read that the 400's have negative deck high,
''Negative deck height'' is when the piston head protrudes above the deck.
Why do you want to increase the compression ?
The pistons mentioned in the above posts would work fine.
But you may or may not have to change the cam also.
Old Apr 2, 2022 | 08:16 PM
tbear853's Avatar
tbear853
I had a coworker ask about boosting compression once. I told him to drill holes in the piston tops and put bolts in the holes and lock-nuts underneath, the bolt heads would act like compression building bumps. He thought I was serious. Don't do that.
Old Apr 3, 2022 | 03:00 AM
6 by 8's Avatar
6 by 8
That's funny.
Old Apr 6, 2022 | 08:26 PM
RalphXL's Avatar
RalphXL
You could have your block decked to the correct height for your stroke, rod, piston stack height. The block probably isn't square anyway.. That way you could use stock dimension parts too.
Jess
Old Apr 6, 2022 | 08:36 PM
ivsamhain's Avatar
ivsamhain
Jess
yup but cutting about .060 off isn’t going to let you use an intake with stock dimensions.
Old Apr 6, 2022 | 08:41 PM
RalphXL's Avatar
RalphXL
Probably would have to cut the China wall down a bit.
Jess
393STROKER
Jan 5, 2012 09:04 AM
TMI
Jun 2, 2005 08:23 PM
TMI
Aug 10, 2004 02:04 AM
Hidome
Jan 20, 2003 09:27 AM
bigred
Feb 14, 2001 04:47 PM
