c6 automatic gearbox question
Old Mar 30, 2022 | 10:59 AM
pp 63's Avatar
pp 63
Smile c6 automatic gearbox question
c6 automatic gearbox question,
Good morning all .... i will need your advice and your insights... i am the proud owner of a ford f 150 4x4 with 400 engine and c6 gearbox i noticed a detail that bothers me.. i think it's just an adjustment but I would like confirmation from you... indeed I noticed when I put the gear selector in the rear position without accelerating the wheels start to spin backwards and when I put position D. even at idle I have to put my foot on the brake otherwise the ford advances and wants to advance even with a correct idle ... and 3 things I find that when I start in d and the vehicle starts it feels like a clutch which slips on a car with manual gearbox.. the 1 and the 2 seem to me to slip as if the clutch is worn but everything goes normally suddenly the ford starts slowly I have to accelerate very hard to start it after once launched it rolls but in recovery it slips .. I do not know if I explained myself well ... the pipes are in good condition no leaks the liquid in the box is ok the kick down also works but "slips" it is why I wanted to know what the adjustment of the brake band corresponds to I know that it is regulated but if the band is too tight it can come from there or if it is not tight enough it also could come from there ... a big thank you to all for your feedback ... cordially .. pat
Old Mar 30, 2022 | 12:25 PM
dlburch's Avatar
dlburch
it's normal for the truck to start moving with no additional throttle.
do you know if you have an after-market stall torque converter (which would require more RPM to fully engage?
have you checked the fluid level?
Old Apr 5, 2022 | 07:07 AM
pp 63's Avatar
pp 63
hello .. thank you for your answer then for the stall torque converter .. I don't know .. for the gearbox fluid level apparently yes it is good I will double check .. when I put the wheels in reverse the wheels tend to skate backwards.; the truck jumps when I'm not accelerating .. and I find that "in forward gear I have to press the accelerator pedal to start it it seems very soft to me like a manual clutch slipping it couldn't come from the adjustment of the brake band?? in your opinion?? thank you for your help have a nice day to you:-clin d'œil
Old Apr 5, 2022 | 10:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Do not adjust anything on the transmission. What you are describing is how it was designed to operate.
Old Apr 6, 2022 | 06:21 AM
pp 63's Avatar
pp 63
hello ... MARC thank you for your answer .. I have never driven such a vehicle before it seemed strange to me if you tell me that it is normal it reassures me but I find that it causes a huge loss of power given the engine and causes significant fuel consumption .. otherwise I love this ford .. thank you good day to you last question how many miles do you get in miles per gallon with such a vehicle?? to know engine v8 400 m carburettor 2 bbl box c6 automatic axles origin wheels 33/12.50/15 to give me an idea..:-clin d'œil
Old Apr 6, 2022 | 07:47 AM
6 by 8's Avatar
6 by 8
Your truck looks great.
Get yourself a C6 manual, or at least get the specifications required, and check the bands.
Too tight, and too loose, have implications, and they are definitely adjustable, just like brake drum shoes are.
Band adjustment is a standard service requirement.
Check them, adjust them if need be, drive around, and 'feel' a difference, if any.
With regard to fuel consumption, ensure the tire pressures are correct, and ensure that vacuum advance ignition timing actually works.
Just those two things can both rob a vehicle of 10% gas efficiency.
Transmission slipping can rob gas mileage.
An untuned carb or undialed in timing curve can rob gas efficiency.
Your engine/transmission state of tune, together with your driving style, will determine your mpg, so anything between 8mpg and 12mpg is possible, as an off the cuff guideline.
Old Apr 6, 2022 | 10:35 AM
Mark Kovalsky
Originally Posted by 6 by 8
Y
Not for very long. A slipping transmission won't last 10 miles (16 kilometers) before its destroyed.
Old Apr 7, 2022 | 03:19 AM
6 by 8's Avatar
6 by 8
Agreed, 10 miles, if anything at all, but that's in the case of extreme examples.
pp 63 needs to start with the easy stuff, and band adjustment is just that.
If he's unlucky, and the band linings are worn, then that becomes an extreme issue.
Vlad91
Oct 7, 2021 12:08 AM
f150tilt
Nov 17, 2019 11:50 AM
mitchell390
Dec 18, 2011 01:02 PM
lumbermansvo
Aug 23, 2007 09:30 PM
