floorboards
Old Nov 7, 2003 | 02:49 PM
slntnddly's Avatar
slntnddly
Question floorboards
in a 75 f100, what is involved in replacing the floorboards? i have a few small rust holes in them that i would like to get rid of.
75f f100
302/ 3spd auto
Old Nov 7, 2003 | 03:57 PM
bigf150's Avatar
bigf150
You cut the old ones out and weld the new ones in its as easy as that if you have a welder
Old Nov 7, 2003 | 04:31 PM
F150daniel's Avatar
F150daniel
If you're looking the holes from under the truck you have a bigger problem than a few small holes. trust me i know.
to do it RIGHT you need
welder
drill
spot weld cutter bit
grinder
hammer
something to cut sheet metal(i.e sawzall, die grinder, plazma cutter)
clamps or strong manets
lots of comon sense
STEP 1 get a floor pan replacement panel.
STEP 2 remove seat, carpet, and any thing else flameable.
STEP 3 lay new panel in place and trace around it, be sure to get real close. if the replacement covers all the rust, good. now lay the replacement panel aside for now.
Cut any spotwelds that the new panel will cover with the spot weld cutter bit. cut the old panel out just in side the traced line. Remove old panel and lay new one in place to test fit. trim from the floor broard till the new one fits in the place of the one without overlapping but no big gaps either. it should look like this
|old panel||new panel||old panel|.
put new panel in the old panels place and clamp and tack weld the corners. put tack welds between the tack welds, do this untill tack welds are about an inch apart, this helps to prevent walping. now make a 1'' weld then weld on the opposite end of the panel, let cool. repete this untill done, and respot weld the spotwelds.
Grind the welds flush with panel being careful not to over heat the panel. coat floor boards top and bottom with POR15 or a similer product. you're done and if you did it right you won't be able to tell it was ever done.
thier are easer ways to do this but this is the right and best way.
Sounds like fun hu?
If you aren't up to it you could get a bodyshop to do it like i described.
or you could always poprivet a piece of sheet metal over it but it would come back in a few years and you would be doing it again and have a bigger hole to cover.
POR15
Old Nov 9, 2003 | 11:42 PM
chevey hater77's Avatar
chevey hater77
I just fixed many rust holes in my 77 what i did was i got a few
rust free car fenders that i had lying around and made patches
out of them using my grinder. then i welded them overtop the
holes using the lowest temp setings my welder had so i wasent
to put more holes in the floor. after i did this i bought some tar
and painted the underneath to prvent any more rust through.
Old Nov 10, 2003 | 08:11 AM
laptopgeek's Avatar
laptopgeek
....now how 'bout fixing a rusted out COWL and fresh air vent area?..... A-A-a-r-g-H!!....
Old Nov 10, 2003 | 01:21 PM
bond10's Avatar
bond10
your vents might be too small or to big
Old Nov 10, 2003 | 03:09 PM
F150daniel's Avatar
F150daniel
harrison must be a northern truck.
go to the junkyard and find a rust free one and start cutting spot welds. replacing the cowl is a ****load of fun.
Old Nov 10, 2003 | 03:16 PM
laptopgeek's Avatar
laptopgeek
F150daniel ~
10-4 on cutting the spot welds!!
Actually the previous owner wasn't a real "rocket scientist" and parked the poor beast under some pine trees for several years and then kicked the bucket. That's when I stepped in and rescued the poor critter. Through the past 3 years, the pine needles collected in the cowl vent area and retained water and rusted the cowl through and other areas of the upper body I found out this week-end. I am presently looking for another body if anybody hears of one. I am keeping my eyes on the classifieds here and Ebay. Ebay has them every once in a while - I almost picked a BRAND-SPANKING-NEW one a few weeks ago until I heard I was going to lose my job.
So's...I'm back to looking....I'm afraid with as much cancer I saw underneath the dash, I'm really surprised the body is still sitting on the frame ---- the previous owner used the poor beast for a trash truck - I'll never haul more than a loaf of bread in him when I'm finished with him....
Old Nov 10, 2003 | 03:25 PM
F150daniel's Avatar
F150daniel
"The hidden junkyard" has some in better shape than yours
lemasters f100
May 30, 2014 03:20 PM
rwrogers
Mar 8, 2014 05:54 AM
lemasters f100
Jul 7, 2012 11:04 PM
ShaggyCorman
Feb 1, 2005 08:04 PM
