Sponsored by: Real Truck
checking Transmission fluid level 6R140
Old Apr 1, 2022 | 09:28 AM
johnnysuede23's Avatar
johnnysuede23
Probably a simple question for someone who knows transmissions. I looked at the manual and it's not entirely clear. Should the transmission fluid be checked with the truck running? I know from the manual that it says check fluid on a level surface and when transmission is warm, it's just a bit unclear about running vs not running.
Thanks
Old Apr 1, 2022 | 09:45 AM
bryyce62's Avatar
bryyce62
Yes. Running on level ground. Fully warmed up.
Old Apr 1, 2022 | 04:42 PM
droldsmorland's Avatar
droldsmorland
X2 running in park hot on level ground.
Filter and fluid should be changed every 30K less if you tow heavy.
Jerseyman32
2004 - 2008 F150
Oct 17, 2021 11:16 AM
96DRW
Jul 1, 2012 10:01 PM
monty0
Nov 6, 2006 09:29 PM
jb666
Sep 12, 2003 01:38 PM
