Sponsored by: Real Truck
Checking tran fluid level
Old Jul 1, 2012 | 03:52 PM
96DRW's Avatar
96DRW
I'm almost embarrassed to ask this question but... what is the best way to check the transmission fluid level on a 2000 F250 5.4L auto tran.
I take it out for about a 10 mile drive to warm things up. The truck is running and level when I check the fluid level. It seems like I can check the fluid level five different times in one sitting and get five different readings. Sometimes the side with the cross hatches appears to have no oil on it but the other side has oil up to the top of the cross hatches. I'm kind of obsessing about this because I want to have the proper amount of tran fluid in there before I start towing this summer. I have had other automatics and have never had much of a problem with checking the level.
When the truck is cold is there a level the fluid should be at? At least that would give some piece of mind.
Thanks
Old Jul 1, 2012 | 05:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When cold there is no way to check the level.
You are checking it correctly. Read the lowest level on either side of the stick.
Old Jul 1, 2012 | 08:36 PM
96DRW's Avatar
96DRW
Thanks for the info. I guess I need to add some - on one side it barely covers the rounded end. On the other side the fluid is present about an inch from the bottom of the stick.
Old Jul 1, 2012 | 10:01 PM
Ridenred333's Avatar
Ridenred333
Thanks
I get the same issue it bugs the crap out of me. First ten times I pulled the stick I was like wtf.
99ExpyProblems
Sep 30, 2013 01:50 PM
UaVaj
May 5, 2010 12:49 PM
dcdave
Sep 2, 2007 11:18 PM
GeneStoner
General Automotive Discussion
Feb 11, 2005 10:22 AM
dalfollo
Apr 7, 2004 03:32 PM
