Mirror arms
Old Aug 12, 2022 | 06:05 PM
49fordv8f4's Avatar
49fordv8f4
Joe, they are going to look good on your truck! When I fastened the mirrors I bought for my truck, I went to Lowes or Home Depot and bought stainless hex head sheet metal screws that fit the holes in the mirrors. You can also replace all the rusty acorn nuts and bolts with stainless ones from Lowes or Home Depot. My mirrors came new with all galvanized fasteners. I replaced them all with stainless steel.
Old Aug 12, 2022 | 11:25 PM
52 Merc's Avatar
52 Merc
Originally Posted by Harrier
The mirrors arrived today. I had to run out, unpack them, and do a quick test fit. I think they will work well. I might have to tweak them just a tiny bit to fit up.
So, any special screws I should use to fasten them to the door? I'm hoping I can tweak them enough to use one of the existing holes from my old mirrors, we will see.
Unless you're totally bent on originality, I'd go with nutserts (aka, rivet nuts or rivnuts) and stainless buttonhead bolts, the same fasteners that the OEM has been using on truck mirrors for the last 40+ years. Nutserts, if you're not familiar, attach like a pop rivet, won't pull out like sheetmetal screws, and stainless fasteners won't rust up and seize as long as you dab them with some proper lube. It'll keep you from having to fumble with nuts and bolts working on both sides of the door at the same time. If you can't stand the look of buttonheads on your old truck, some typical hex head bolts would work just as well, too.
Old Aug 14, 2022 | 08:19 PM
Harrier's Avatar
Harrier
I will have to go with those I would feel much more comfortable with something like that. I will definitely need new acorn nuts. I only broke 2 of the 8 when I was taking them apart this evening.
I also got to pondering if I wanted to put these mirrors on my old frames. They would use the existing holes, but it might not look quite as good. We will see as I play with them more.
Old Aug 19, 2022 | 07:51 PM
Harrier's Avatar
Harrier
So I went to Menards to get some nutserts (they were the only place that had any) I got ones too big, I need much smaller ones. 1/4 - 20 require a big hole.....should have known that.
Well I went to my truck and grabbed a 1/4' bolt to use to compare size. Low and behold it screwed right into my old hole and held on very well. If I recall correctly there were sheet metal screws holding the mirrors on.
I might play with that a bit....
Old Oct 16, 2022 | 08:43 PM
Harrier's Avatar
Harrier
I got to working on my West Coast mirrors. On my originals one of the sections was rusted through and broke as I was working on it.
So I went out to Orschlen's (A Farm and Home store here in Missouri) and got a pipe of the same size and made a replacement. I can't believe I didn't take a picture of my final product. It's not real pretty but it does the trick.
I looked all over at Lowes for a pipe of the same diameter and thickness but didn't find it there. Orschlen's had one and only one of that type.
Here they are on the truck. Now to take it out for a test drive. It's closer to what it was when it was on the farm now and I should be able to see better.
Old Oct 16, 2022 | 09:21 PM
abe's Avatar
abe
They look good, Joe. It's nice you can use the original mirror arms to your grandfather-in-law's truck.
Did you paint the arms black?
Old Oct 16, 2022 | 10:12 PM
Harrier's Avatar
Harrier
Yeah, I like that I'm using the arms that were on the truck. I didn't paint them. Parts are rusty and other parts are silver.
They look better in the pictures than they do in real life.
Old Oct 17, 2022 | 06:49 AM
Greg Rogers's Avatar
Greg Rogers
Joe, I would like to have the mirror you took off the right side of your truck. Would you like to sell it ? Thanks Greg.
Old Oct 17, 2022 | 09:32 PM
Harrier's Avatar
Harrier
I will hold off selling them for the moment. My hoarder tendencies are too strong on such a new change.
Nozz
Mar 30, 2021 01:31 AM
HVFDFIREFIGHTER1618
Jul 5, 2020 12:39 PM
bauerb
Sep 14, 2017 01:22 AM
robert_l_ross
Jul 29, 2016 10:11 AM
nightskyisme
Mar 27, 2007 03:24 PM
