DPF % screen on STX trim
I am new to this forum. I have a 2020 F-350 STX DRW Fx4, with the 6.7L. We have had it since July 2020. We live full time in our RV pulling a 5th wheel toy hauler. The truck has been really good so far. It is a great towing platform.
I have downloaded Forscan and have the 2 month extended license. I have backed up the BdyCM and ICM modules. I have not made any changes yet. I have the spreadsheet for 2020-22 Ford Superduty dated 1/05/2022.
I have searched for an example picture of what the dash Maintenance Monitor screen looks like when the DPF % screen is added, but can only find examples of the higher trim screens.
does anyone on here have the same dash display with that screen enabled? I would like to see one before I make any changes.
I have looked at various DPF parameters in forscan while connected to truck.
I have been to the IPC module page showing
DPF% on screen IPC 720-07-02 x*xx xxxx
Some trucks will report a camera error after making this modification. To avoid
this, update according to the following: If original default value is 0, change to 8; if 1,
change to 9; if 2 then A; if 3 then B; if 4 then C; if 5 then D;if 6 then E, if 7 then F.
My truck has a 6 where the * is. So, when I get brave enough I will put an E in that place.
Also, with this dash display I can see Trans temp and Oil temp, but not coolant temp. I don't see any place to add coolant temp to the gauges on this type display.
I know the tire pressure light is on. I was dissappointed that the inner left rear TPMS quit recently. That is less than two years. I hope an anomaly and not a trend. I tried to clear the codes and even retrained the TPMS system, but it will not work.
Thanks for any advice or replies.
Doesn't seem anyone knows or haven't seen this post with the 6.7 STX. Maybe a MOD could move this the 6.7 forum or ask in that section of the forum.
https://www.ford-trucks.com/forums/forum205/
Here are some photos:
Here you can see the "Exhaust Filter" option in the regular list. (Note that mine is currently at 55%.)
When I scroll down to the Exhaust Filter option and click "OK" this is the screen that opens up.
Also, when you enable the "Auto Regen" check box, it appears under the Advanced option lists and is the first one in the list.
Hope this helps.
