Starter install
Old Mar 31, 2022 | 09:22 AM
dans 51 f2's Avatar
dans 51 f2
Starter install
I had my 51 flathead v8 starter rebuilt. they told me they put a heavy duty drive on it due to 12 v system. I have read on hear about those being larger. I have very little room to maneuver the starter due to the oil pan and exhaust pipe. any suggestions on how to install? I have read you need to tilt the starter toward the engine to clear the flywheel. could I remove the oil pan to install the starter, or maybe the transmission and flywheel? any help will be greatly appreciated. thanks.
Old Mar 31, 2022 | 09:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Can you post a pic of the drive? There are "heavy duty" and "new style" drives. The fitment problems are usually with the "new style" drives, just takes persistence.
Old Mar 31, 2022 | 12:35 PM
mtflat's Avatar
mtflat
They're not much larger than the stock bendix. It will fit just fine.
I run one on the starter of my 48 that I switched to 12V.
Old Apr 12, 2022 | 04:20 PM
dans 51 f2's Avatar
dans 51 f2
Starter is in
So I finally took the start back to the rebuild shop and had them change the drive to an older version. I had it installed in less than 5 minutes after fighting with the other one for days.
Old Apr 12, 2022 | 07:07 PM
abe's Avatar
abe
That's good. Thanks for the follow up.
1966F100SC
May 30, 2021 02:50 PM
schoo
1947 and Older Ford Trucks
Sep 11, 2012 07:05 PM
1974F100
Jan 24, 2007 04:34 PM
Flaflathead
Sep 10, 2005 01:33 PM
BroncJMU
1978 - 1996 Big Bronco
Dec 21, 2004 08:20 PM
