Electrical Issues
Old Mar 30, 2022 | 08:35 PM
Tyler18's Avatar
Tyler18
Electrical Issues
Hi Guys/Gals,
I'm new here, My name is Tyler and i have recently purchased a 99 F350 7.3L it runs fairly well for what i can tell. That being said I do not have a whole lot of experience working on diesels.
The other day I was driving to work and the truck completely shut off on me. A few things that I ran through were as follows; it was a little low on oil maybe about 2.5Q, hpop and lpop are fairly new within 3000 miles, as well as a new smaller turbo, I have topped all fluids and truck still wouldn't start. I then went through the fuses and found one that had popped. me and my father had then tried to use a wire to temporarily jump the connection to at least get it running and it worked. we then turned it off and replaced the wire in the fuse box with the correct fuse. this seemed to temporarily fix whatever issues the truck was having that didn't allow it to start. we believe it may be a short in the wiring in the valve cover. As this is something that my dads mechanic friends said is a common issues. Can anyone shine some light here so that I can comfortably use my truck. I just don't want to spend the time taking everything off just to find out I could have done a simpler fix.
Old Mar 31, 2022 | 02:45 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Hey Tyler! Welcome to FTE!
One of the great things about these trucks is they will stop running when the oil gets too low. Prevents catastrophic failure.
Which fuse blew out? That will point us to the issue.
The best tool in your arsenal is Forscan app on your android, and a BT adapter so you can read codes, monitor sensors, and run tests.
As to BT adapters for the OBDII port there are many, cheap to expensive, do some research.
Where are you located?
Old Mar 31, 2022 | 07:09 AM
udsuth78's Avatar
udsuth78
Which fuse popped? Is your fuel bowl heater still connected? If it is then unplug it and leave it that way. Fuse 19 I believe is the one that is shared between the PCM and bowl heater. If that was your guy then likely, mystery solved.
Old Mar 31, 2022 | 07:35 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Hey @Tyler18 , welcome to the FTE!
The fellas above have you pointed in the right direction and we look forward to any additional information you can provide to us.
Adam Chrisman
Jun 28, 2019 08:34 AM
Mdt1992
Apr 27, 2013 12:15 AM
benspeedbarn
Modular V10 (6.8l)
Jun 20, 2010 08:50 AM
