Old Oct 7, 2012 | 07:41 PM
vmlb's Avatar
vmlb
5th Gear
Drove it 100 yds. and it just stopped. It cranks well and thought I had run out of gas. Put gas in it and it still doesn't start. Possibilities?
Old Oct 7, 2012 | 07:45 PM
tiap's Avatar
tiap
Squirt some starter fluid into the throttle body while cranking. That will tell you quickly if it's an ignition or fuel issue.
Old Oct 7, 2012 | 08:03 PM
vmlb's Avatar
vmlb
5th Gear
Thanks, will try
Old Oct 8, 2012 | 10:40 PM
feeniks4.9's Avatar
feeniks4.9
Ignition coil failure. Common problem with Fords in general.
Old Oct 9, 2012 | 10:23 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I would suggest that a TFI or PIP failure is more likely than a coil failure.
That said, I recently experienced a coil failure on 4.9 - first one I ever had fail on any Ford I've owned. Is there any reason why a 4.9 is more prone to kill a coil than other engine? Can't think of anything, but thought I'd throw it out there.
Old Oct 10, 2012 | 10:38 AM
feeniks4.9's Avatar
feeniks4.9
Doh! TFI is what I meant - thanks for the correction... As to the coil, I'd read a bad or mis-gap in the sparkplugs was thought to be problem.
Old Oct 11, 2012 | 01:11 AM
jem44357's Avatar
jem44357
I would guess it is because it is more exposed to the elements. When mine failed it was because it rusted out.<O</O
Jim
ibuzzard
19
Apr 22, 2008 02:53 PM
john7979
Mar 16, 2005 10:01 AM
twofiddy
General Automotive Discussion
Sep 21, 2004 11:27 PM
lgmccollum
Electrical Systems/Wiring
Sep 30, 2003 12:28 PM
