Sponsored by: Real Truck
Replacing V10 Fuel Filter
Old Nov 7, 2003 | 11:18 AM
generubin's Avatar
generubin
Can somebody please explain to me if there is a special trick or special tool required to replace the gas fuel filter on my 2003 Super Duty. The lines are well locked on. Has anyone used Fram filters or do I need the Motorcraft? Thanks in advance!
Gene Rubin
Old Nov 7, 2003 | 11:21 AM
jetjock16's Avatar
jetjock16
its about a 24 second job.. if your taking longer than that your doing it wrong.....Belive me i too learned the hard way....You do need a special little tool, its like a plastic deally that slips over the line then into the filter to unlock the little barbs.... i borrowed one from the AF base auto shop and the filter poped right out.
Old Nov 7, 2003 | 12:47 PM
MarkF250's Avatar
MarkF250
Yep, what he said...
Old Nov 7, 2003 | 03:27 PM
Oldchap's Avatar
Oldchap
Most autoparts stores have the tool. I got mine at NAPA, along with the filter.
Old Nov 7, 2003 | 04:47 PM
generubin's Avatar
generubin
Got it, thanks!
I got the nice aluminum tool at Pep Boys. Did the job in seconds. This is my first American truck. The japanese ones all had banjo fittings.
Thanks to all, Gene
Old Nov 7, 2003 | 05:43 PM
bigdawg460's Avatar
bigdawg460
Re: Replacing V10 Fuel Filter
Gene Rubin
Yep its pretty easy with the tool,but you must be careful that you keep the line pushed onto the filter until you release the fingers in the connector,other wise you could bend one of the fingers over,and dont try pulling hard if it doesnt come .This also can damage the fingers in the retaining cage.But if this happens just cut the end of the old filter with side cutters ,take a pick and remove/replace the cage (they are replacible).I had a couple of guys bring there trucks to my shop after they couldnt get it,and that was the result.hope this helps
Camper Special Gene
Mar 8, 2013 09:09 PM
gene wahrmund
2009 - 2014 F150
Sep 28, 2012 01:23 AM
WB9PRG
1983 - 2012 Ranger & B-Series
Mar 22, 2007 04:02 PM
meangenejr
Oct 16, 2004 04:43 PM
