spedometer conversion
Old Nov 7, 2003 | 10:37 AM
ckite's Avatar
ckite
i've got a 95 f150 xlt and i was wondering if a spedometer from a lightening will work in my truck, and if so, will my mileage be accurate or will it be messed up?
Thanks for the help.
Old Nov 7, 2003 | 10:41 AM
MustangGT221's Avatar
MustangGT221
The mileage is stored in the speedo, so you'd have to have it changed.
Old Nov 7, 2003 | 10:44 AM
ckite's Avatar
ckite
how would i get the mileage on the spedo changed
Old Nov 7, 2003 | 04:40 PM
MustangGT221
Dealer can do it, or contact steve83, he knows a way that you can do it with a radio I think.
Old Nov 9, 2003 | 12:23 AM
steve83's Avatar
steve83
I used the shareware program GoldWave to create a sine wave at 3KHz to simulate the ABS sensor in the rear axle at ~80 mph to run up miles on a PSOM. I played the .WAV file on my computer through the sound card to the stereo and hooked the speaker wires to the PSOM's speed sensor terminals, and adjusted the volume JUST loud enough to make the speedo detect it. After a few days, I had the odometer where it needed to be.
If you buy it new from a Ford dealer, they can order it with your mileage already programmed into it.
The second step is to set the conversion constant in the PSOM to your tire size so registers the correct mileage as you drive. I've posted that procedure already: https://www.ford-trucks.com/forums/s...hreadid=104045 Read my SECOND post in that thread.
Boodrow379
13
Jan 15, 2014 05:12 PM
fivepointohno
Oct 12, 2012 03:24 PM
therifleman556
Mar 21, 2009 06:02 AM
rriveroll
Jun 15, 2008 04:51 PM
slappy78
1983 - 2012 Ranger & B-Series
Oct 4, 2002 06:16 PM
