Best Stainless Bed Rail Caps ??
Due to the clear coat dying on one of my trucks bed rails, I am considering going with something like bed caps to make it look nice again. I am interested to hear what others have to say about the brands that are available for stainless steel bed caps for our trucks. I'm looking at the smooth polished stainless ones not really interested in the aluminum diamond plate ones for the bed rails and the tailgate and would like to also maybe even get a bulkhead one. What options are there and which ones fit the best? This is for a short bed.
For my part, I'd repaint the truck before I put those caps on it. Just from personal experience, basically all of that sort of stuff, like bed caps, fender flares, and the like are nothing but moisture collectors, that cause rot. But I'm in a rather wet part of the country.
I went with those because it looked good on a black truck and I was tired of the diamond plate that caused rust. They didn't work out very well. Wouldn't stay installed in the TX heat. Both the double sided tape and different adhesives did not hold them on. Also one blew off on the freeway after multiple attempts to keep it stuck in place. They are also really flimsy. They were only on the truck about 6 weeks. Would not recommend and consider them to be junk. I actually ended up using a DIY bedliner type of paint on those rails.
Hmmm, I did the rattle can spray liner on mine, did you use roll on, if so did it hold up, to the wifes dragging metal across it...mine dont.
, but it looks better than I thought, hid all the PO gouges.
I didnt care for the black over maroon, I thought of trying to use the paint code(EG) is mine, and see how bad that looked over the black texture look, like the rhino lining you can get color match(close) put in bed, just to check, if no good then back to black.
Spirit615
Oct 9, 2007 07:33 PM
murdocksvillian
Jun 21, 2007 04:33 PM
78-f150-4x4-351m
Mar 1, 2006 06:33 AM
