Windshield Washer Pump & Tank Replacement?
Old Mar 19, 2022 | 09:50 PM
old28's Avatar
old28
I am replacing my windshield washer pump & fluid tank in my 1971 F250 300 4.9L. This setup has the pump mounted inside the bottom of the fluid tank. The pump has a rubber mounted on the end that seals to the tank material.
I have seen on the Web & U-tube that some have had trouble with the seal leaking fluid after the installation. Should the rubber be lubed before installation? What type of lube? Thanks for the help.
Old Mar 21, 2022 | 04:11 PM
AAubinoe's Avatar
AAubinoe
Hi,
I just installed a reproduction tank. I always use dielectric grease on stuff like that.
This is the tank I used in my 69 F250, but it looks like the 71 maybe different?
https://www.dennis-carpenter.com/tru...reservoir-wcap
Old Mar 22, 2022 | 10:07 AM
old28's Avatar
old28
AAubinoe - Thanks for the idea on the dielectric grease. The 71-72 tank is not the same, bit more square in shape. DC is out of stock for the 71, may have to get it from LMC.
Big-Red-Lariat
2015 - 2020 F150
Sep 11, 2025 06:43 PM
The Old Truck
2009 - 2014 F150
Feb 13, 2022 10:30 AM
woods
Nov 4, 2005 08:08 AM
Bikerider900
Sep 7, 2003 04:19 PM
luxury 4x4
1978 - 1996 Big Bronco
Jan 3, 2002 08:46 PM
