brake lights
Old Sep 8, 2002 | 09:24 PM
wolverineflight31's Avatar
wolverineflight31
brake lights
Hey guys,
I just realized my brake lights either don't work or I do'nt have them. I am not about to drive down the road without brake lights because that sounds kinda dangerous. Did my truck not come with them or are they just not working? How do you check what's wrong? Thanks guys. What about back up lights too? thanks again!
Old Sep 8, 2002 | 09:48 PM
LxMan1's Avatar
LxMan1
brake lights
They all came with them. Does yours have the single style master cyl. on it. The round one with a twist on cap? If so, the brake light switch is on the front of it and works off of system pressure. I'd start there.
Old Sep 9, 2002 | 07:53 AM
yenima38's Avatar
yenima38
brake lights
Try checking your light bulbs, do you have tail lights when you turn your headlights on. If so your getting voltage, and the switch may need adjusting. Or the fuse could be blown. If your unsure how to do any of this, take your truck to a certified mechanic.
[br] [br]Randy - Just another Ford Lover
Old Sep 9, 2002 | 07:10 PM
wolverineflight31
brake lights
Thanks guys,
I'll check that stuff tomorrow to see if I can get it sorted out. It is the single master cylinder with the screw on lid by the way. Thanks again for the reply's!
Old Sep 10, 2002 | 10:20 AM
huitt24's Avatar
huitt24
brake lights
also the rear brake lights wont come on unless the key is in the run position or the truck is running to save your points.
66 F250 390 4spd PS/PB Camper Special Custom Cab
66 F250 352 4spd Camper Special Custom Cab
Old Sep 10, 2002 | 04:45 PM
a63unibody's Avatar
a63unibody
brake lights
>points.
I've never heard that one before!
Robert
Old Sep 10, 2002 | 05:46 PM
LxMan1's Avatar
LxMan1
brake lights
Me either, mine work unless the battery is unhooked!!!!
Old Sep 11, 2002 | 10:44 AM
oldroady's Avatar
oldroady
brake lights
they work on a dual filament bulb. check your turn signals, if they work, then it's the switch. located on master cylinder front, hydraulic, costs about five bucks.
Old Sep 11, 2002 | 02:12 PM
shasta's Avatar
shasta
brake lights
My 66 brake lights only work with the key in the on or run position.This is the way all 66 were wired from the factory.I think 65 was that way too.Earlier years had the brake lights come on with the key off
Andy
Old Sep 11, 2002 | 04:15 PM
a63unibody's Avatar
a63unibody
brake lights
>Andy
My brother in laws 66, which he has owned since new comes on without the key on, I've never seen a auto with the setup you have,
Robert
Old Sep 11, 2002 | 04:17 PM
Rosati's Avatar
Rosati
brake lights
Check the fuse first and make sure it's at least a 15 amp fuse.
Old Sep 11, 2002 | 09:18 PM
leonharu's Avatar
leonharu
brake lights
For a quick check take the two wires off the brake light switch and connect a jumper wire between them.If you have brake lights now your switch is bad!
Rusty
Old Sep 13, 2002 | 07:31 AM
Zen_1963_Unibody's Avatar
Zen_1963_Unibody
brake lights
Just for the record, my 51,000 mile original '63 F100's brake lights won't come on unless the ignition is on. Hmmmm, Kansas City? LOL.
-Zen-
Old Sep 14, 2002 | 07:56 PM
uglyblue66's Avatar
uglyblue66
brake lights
Mack
Funny you should ask about backup lights. I just got mine wired this evening. Your truck did not come with backup lights. But they are easy to install with all factory componets. The tailights from a 72 back will fit right in the factory holes. When you remove the light, get EVERYTHING.^The backup lamps use a seperate bulb and you need all the fixture to upgrade.. You also need to leave as much wire as you can. Install the lights and run a hotwire up to the front of the truck.
Also check for a factory backup light switch on the 72 style truck. It clamps around the lower part of your column. It is activated when your shift arm hits it when you shift to reverse. Just remove and retain all parts and reinstall it on your truck. Run the wires and be sure to use a fuse. My taillights with back up light fixtures came from a 1970 ford van.I used a seperate lighted switch until I can find a factory 1 at the junkyard..........mack
Old Sep 15, 2002 | 03:57 AM
jowilker's Avatar
jowilker
brake lights
