Blinker lights goin crazy
Old Jan 21, 2017 | 09:46 PM
Redstroker73's Avatar
Redstroker73
so all of a sudden I put my blinker on and it was flashing fast. My first response was to check if a bulb is out, not the case. Five minutes down the road my brake lights stopped working and the 3rd brake light stays on.. when I put a blinker on the rear lights and 3rd brake light and the lisence plate plate lights all flash at once. Any suggestions?
Old Jan 21, 2017 | 10:05 PM
Firefighter 1406's Avatar
Firefighter 1406
Sounds like a loose of ground somewhere possibly. I know in trailers that do that have a ground issue somewhere. Melted wire, etc.
Old Jan 22, 2017 | 05:46 PM
hydro man 17's Avatar
hydro man 17
Another thing to check is the turn signal switch itself. Not sure if it is a simalar design like they were "back in the day" but they also have the brake lights and tail lights switched through it. If the switch itself is messd up all kinds of wierd things can happen.
Old Jan 23, 2017 | 08:51 AM
pirschwagon's Avatar
pirschwagon
I would begin with the MFW as well. Also, the 3rd Brake Lamp is on a separate circuit and should not be affected.
danman223
Aug 9, 2018 01:31 PM
dustyroad
19
Aug 14, 2016 09:57 AM
mofoco1
Jul 14, 2016 08:02 AM
Masterjqx
May 13, 2013 05:26 AM
bbender85
Feb 4, 2009 01:10 PM
