Speedo needle replacement
Old Mar 17, 2022 | 12:32 PM
thomc's Avatar
thomc
The needle on the speedometer in our '56 Panel is loose from the stem. One of my spare speedometers looks like it would work, but the needle is broken(see the pic). Anyone ever remove and replace a needle? Tell me how, please. Thanks.
Old Mar 17, 2022 | 12:48 PM
thomc's Avatar
thomc
Here's my other spare speedometer. It appears to work, but the needle is broken on it. I'm thinking some epoxy, JB Weld maybe. What say ye?
Old Mar 17, 2022 | 01:10 PM
thomc's Avatar
thomc
Oh, I would also like to reset the odometer back to 00000.0 before our maiden voyage. I've seen replacement number wheels advertised, but have never disassembled and reassembled a Ford speedo before. I have never been a used car/truck dealer so don't have much experience rolling back odometers.
Old Mar 17, 2022 | 02:08 PM
abe's Avatar
abe
I've never fixed nor replaced a needle. I just replaced speedo heads into the instrument panel.
I think using JB Weld might add to much weight to the delicately balanced needle. Maybe a drop of Super Glue would work.
Old Mar 17, 2022 | 02:12 PM
56panelford's Avatar
56panelford
https://www.ford-trucks.com/forums/1...ter-reset.html
Old Mar 17, 2022 | 02:15 PM
abe's Avatar
abe
About resetting your odometer. I did mine back in 1999. So I forget the details, but remove the odometer. Once it's on your workbench you can carefully take it apart. You have to do one column at a time. There is a trick to this that I forget now. But you'll figure it out . It is a slow process. Maybe you can find a how to video on YouTube.
Old Mar 17, 2022 | 02:16 PM
56panelford
What about the link I just posted..
Old Mar 17, 2022 | 02:36 PM
abe's Avatar
abe
I guess I was writing my post while Quick Fingers John had already posted his.
Old Mar 17, 2022 | 06:35 PM
thomc's Avatar
thomc
Thanks, 56panelford, after I watched the video I reset one of the odometers back to 0. I'll use it in whichever cluster I use.
I watched some vids about super glue & baking soda. Obviously adding the baking soda causes the super glue to harden immediately and super hard & strong.
I'll try to use a very small dab of glue, with a toothpick, and see how it goes.
Old Mar 18, 2022 | 03:46 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The needles are just friction fit on the shaft. You can grab the shaft with a needle nose pliers and hold it while prying up at the base of the needle, I would use a nylon pry tool. I have taken several apart over the years.
Old Mar 18, 2022 | 08:00 AM
thomc's Avatar
thomc
Yeah, I've done the same on old GM speedometers several time myself, but these Fords have a very delicate coil spring (looks like a spring out of a watch or small clock) just behind the needle, that I'm not familiar with. I hate to destroy a speedo to find out more!
FuzzyBeanBag
Aug 9, 2021 01:53 AM
abe
Sep 22, 2016 03:32 PM
avf100
Jul 28, 2014 10:24 PM
Nate414
Nov 11, 2011 10:59 AM
polarspeed
Mar 14, 2010 07:01 PM
