Anyone replace a pitman arm lately?
Old Mar 16, 2022 | 03:23 PM
Ford.Dude's Avatar
Ford.Dude
Plan on installing a drop pitman arm soon. My truck has the original and I need to stick a 4inch drop in there. Just wondering if anyone has replaced one lately so they could tell me how crappy the job was.
Old Mar 16, 2022 | 10:25 PM
LCR's Avatar
LCR
I did it 6 years ago when I replaced my steering box it was a PITA since I did the whole box in my driveway with basic tools. If all you’re doing is the arm it should be cake walk, a few bolts for the steering linkage and you’re good. And by a few bolts I mean there’s a massive bolt that attaches the the arm to box that is 1-13/16 or 45mm and has a torque spec of 300ft/lbs.
I borrowed the socket from a harbor freight 3/4” drive set. No way to torque it so I put a pipe on the end of the 3/4 drive and gave it some German torque.
But if you have the tools it’s straight forward, 1 nut for the steering linkage to the pitman and that massive nut from the pitman to the box.
Old Mar 17, 2022 | 03:54 AM
Yahiko's Avatar
Yahiko
I did one about the summer before this last and found it not that bad of a job.
I did happen to already own a 600Ft/Lb torque wrench from way back when I
had replaced the track bar bushing. That thing takes a bit of torque also.
Old Mar 17, 2022 | 06:06 AM
Ford.Dude's Avatar
Ford.Dude
I've put off this job for years. The horror stories I've heard have caused a stall. Nut working loose after replacement, having to use heat to separate arm from the gearbox.
We'll see how well it'll go.
Old Mar 17, 2022 | 08:10 AM
SmackDaddy's Avatar
SmackDaddy
When I had my stock gear box out and in a vise it took a lot of heating with a torch and nearly broke a puller and when it finally separated it sounded like a gun shot and the pitman arm flew about five feet in the air with the puller. Wear safety glasses, gloves and stay clear of it especially when you are cranking down on the puller tool.
Notice puller arms bending
Heat heat and more heat
Boom!
Old Mar 17, 2022 | 08:39 AM
TooManyToys.'s Avatar
TooManyToys.
That torch image shows heating the shaft, expanding it. I've always heated the arm to get it a little hotter than the shaft. Or is the image just part of what you did?
Old Mar 17, 2022 | 08:41 AM
SmackDaddy's Avatar
SmackDaddy
I heat cycled the shaft and the pitman arm around it, let it cool, heated it, let it cool then heated it and sprayed a little penetrating lubricant in there to draw into the splines. It’s not my first rodeo. I needed a bigger torch though.
You get that engine together yet?
Old Mar 17, 2022 | 09:44 AM
TooManyToys.
That why I asked about the image, it only refers to heating the shaft and others who are not familiar with the process might take it that way.
Its been running for a while.
Old Mar 17, 2022 | 09:45 AM
SmackDaddy's Avatar
SmackDaddy
I never tried just heat cycling the shaft but I bet it would work.
I never saw a thread on your engine rebuild.
Old Mar 17, 2022 | 09:47 AM
TooManyToys.
I don't heat the shaft, in this case only the arm. I would want the shaft to stay as cool as possible. Not my first rodeo either.
Never had one; never intended to.
Old Mar 17, 2022 | 03:32 PM
Yahiko's Avatar
Yahiko
I think the pitman arp puller i have is a bit bigger. I did not have to heat anything.
But then again it was already presoaked with fluid from she damaged seal.
Old Mar 17, 2022 | 09:27 PM
LCR's Avatar
LCR
I'd probably spray some penetrating oil on multiple times for a few days before tackling it it. It may help and it may be snake oil, but $2 to possibly make life a lot easier would sure go a long way.
Old Mar 17, 2022 | 11:20 PM
Yahiko's Avatar
Yahiko
The best one IMHO is Kroil. If not that then use a 50/50 mix of ATF and acetone.
Old Mar 18, 2022 | 06:47 AM
TooManyToys.
I'm starting to try Free All, which was recomended by Hydro/Hydro-Tek.
Old Mar 20, 2022 | 04:24 PM
Fuzzpuss's Avatar
Fuzzpuss
Why do I feel like you had a virtual party and I wasn't invited? I think you owe us some pics Mr Man...
