351W Stroker Build
Old Mar 21, 2022 | 09:43 PM
trhert22's Avatar
trhert22
Okay, another question…
I have access to two 351w blocks. One has no overbore, the other is already at .030” over and suffered a head gasket failure. I am struggling very much with boring a perfectly good block that barely needs a hone but all the stroker kits I can find have overbore pistons. Am I better off trying to mimic a lot and purchase everything separately to retain the factory bore OR am I better committing to boring out the 351 .030”. I’d much rather find a way to not overbore the factory block even if that means I cough up a few cubic inches simply to retain longevity. Or am I looking at this wrong?
Old Mar 22, 2022 | 07:10 AM
torq'ta 5 8's Avatar
torq'ta 5 8
How bad is/was blown head gasket, already overbore, would a good hone clean it up, then save the other, does the overbore pistons need/have special wrist pin locations.
Old Mar 22, 2022 | 07:23 AM
Zrt1200's Avatar
Zrt1200
If you are looking at a complete stroker kit typically they only show over bore sizes. But if you call I am sure you can get a standard bore piston. I have a few question for you though.
1. Is this a roller cam block?? If Yes. Before buying anything knock your cam bearings out and look at #2 & #4 cam bores where the spider trey bolt down for cracks. See link..
https://www.corral.net/threads/must-...-guys.1352369/
2. Did you check your stock bore with a bore gauge to make sure the cylinder walls are straight top to bottom?? If so by all means get a standard bore piston
3. Are you building this engine at home or are you having it built?? If you are building it yourself and don't build engines much I would suggest a $20 subscription per month to SBF building.com. You can subscribe through 351 Stroker Kits and can cancel at any time. There is a ton of valuable video data on his site and IMO the one video on 351 stroker crankshafts is worth the $20 for a month.
Kruse
Jan 21, 2017 11:02 AM
sckootter578
Oct 10, 2007 12:41 AM
jhk1981
Mar 23, 2004 04:56 AM
bigblocksix
Dec 2, 2003 10:00 AM
john22
Jul 27, 2003 02:28 PM
