Trans issues
Old Mar 14, 2022 | 12:48 PM
DaleDent's Avatar
DaleDent
Exclamation Trans issues
Hi all,
My 95 F-250 auto trans started giving me issues. Started out stalling in reverse which quickly lead to stalling while at low speed. Now the truck won’t shift into gear at all. I read that I should check the oil and filter, also the Neutral Safety switch (probably try replacing that today). Any ideas, or tips on where else to start?
Old Mar 14, 2022 | 05:18 PM
FinnishStroker's Avatar
FinnishStroker
Welcome to the FTE!
Check fluid warm,idling in Park.
Look color of the fluid and sniff If it smells burnt.
Pull codes.
If OD light is blinking, there's codes.
Throwing parts blind is bad idea,especially in tranny issues.
General readers doesn't communicate with these vehicles.
OBD reader(BAFX or OBDlink) and ForScan App,for example.
Old Mar 14, 2022 | 07:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by DaleDent
Hi all,
Those are symptoms of low trans fluid.
The neutral Safety Switch (really called the TRS - Transmission Range Sensor) cannot cause these problems. Changing it will not fix this.
Old Mar 15, 2022 | 10:40 PM
DaleDent's Avatar
DaleDent
I found the issue, low fluid is right the trans filter dropped out inside the pan therefore no oil was being picked up.
thanks
Old Mar 16, 2022 | 07:27 PM
Mark Kovalsky
If the filter fell out it probably is a 4x2 filter in a 4x4 pan.
Old Mar 17, 2022 | 09:56 AM
oldbird1965's Avatar
oldbird1965
OR, the filter gasket from the last filter change was left in there preventing the new filter from seating all the way in.
ptmarszalek
Jan 18, 2020 10:31 PM
Blue17
1997 - 2003 F150
Apr 20, 2018 03:11 PM
fyrbrd
May 7, 2010 05:03 PM
mike b
Feb 9, 2003 03:20 PM
