Trans problems, please help!?
Old May 5, 2010 | 03:13 PM
fyrbrd's Avatar
fyrbrd
Hey Guys,
Started on my way home from work today and truck was running fine. Went to pull away from stoplight and suddenly the trans would not shift above 2nd gear. Engine is fine, got it home pulled codes P0750 and P1705
P0750 Shift Solenoid A
P1705 Trans Range Circuit not indicating Park or Nuetral during test.
First question, are these easy fixes?
If not, am I rebuilding a tranny?
Any help is greatly appreciated.
John
96 F350
Old May 5, 2010 | 03:34 PM
chicagodragon's Avatar
chicagodragon
the trans range switch is easy. i dont know about the rest. if you go to get the trans switch, make sure it is the exact one. ford had a hard time find ing mine.
Old May 5, 2010 | 07:33 PM
Brown Falcon's Avatar
Brown Falcon
Yes, try the transmission range sensor. It's on the driver side of the transmission where the shift cable hooks up.
Old May 5, 2010 | 09:08 PM
oldbird1965's Avatar
oldbird1965
Just curious, is there an adjustment to that switch or is it 'just replace it' kind of deal?
Old May 5, 2010 | 10:22 PM
fyrbrd's Avatar
fyrbrd
Falcon,
Would the Trans Range switch also cause the shift solenoid issue? I feel it shifting from 1st to 2nd but then I'm doin' 2500 rpm trying to maintain 30 mph. Will shift into reverse and neutral just fine.
Old May 5, 2010 | 10:38 PM
chicagodragon
If the switch is lying to the pcm, probably so. It may think you ate in low range
Old May 6, 2010 | 05:27 AM
Brown Falcon
It can make it not shift because it isn't sending the signals out right. Also you can check your VSS (vehicle speed sensor) on top of the rear diff. Most of the time you just need to pull it out and clean it off with a cloth and put it back in.
Old May 6, 2010 | 09:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Everybody is OK with ignoring the shift solenoid code? The shift solenoid that makes the trans shift 2-3? I'd think that would be the thing to fix, not the TRS. That code sets if the trans isn't in park or neutral when the test is run.
Old May 7, 2010 | 01:00 AM
fyrbrd's Avatar
fyrbrd
OK, I sent the truck to a local tranny shop. Engines I'm ok with but trannies are a different thing, let's just say I know when I'm over my head. The magnet in the bottom of the pan was covered with metal shavings. One of the ports in the valve body was almost completely clogged with metal shavings. Can anyone say new tranny?
Old May 7, 2010 | 05:03 PM
fordpride's Avatar
fordpride
New Tranny haha Hope thats not the case.
rjjastone
Jan 31, 2017 12:59 PM
real550A
54
Apr 28, 2014 12:20 AM
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
redman84
17
May 29, 2013 12:38 PM
grey1169
Apr 13, 2009 01:48 PM
