Heater Core Next Week - Any tips?
Old Nov 6, 2003 | 09:08 PM
DuckRyder's Avatar
DuckRyder
I'm going to replace the heater core in my 72 non-ac truck early next week?
Any tips?
Got new heater hoses and a heater core on the way.
(Search didn't turn up much.)
Old Nov 6, 2003 | 09:23 PM
banjopicker66's Avatar
banjopicker66
It is pretty simple, since you have the non-ac box. Three nuts on the firewall under the hood, take off the hoses and the cables under the dash, and it comes right out.
Be careful of the defrost hoses; they can be fragile.
Also, don't throw that heater box around too much. It is fiberglass, so it cracks and breaks quite easily.
Disassembly is pretty straight forward.
2 hours at most to do it.
Old Nov 6, 2003 | 10:09 PM
willowbilly3's Avatar
willowbilly3
I always test the new heater core under water buy putting air pressure to one pipe while holding my thumb over the other. Over the years I have had maybe 10 new ones that leaked. It is no fun redoing a heater core that was a 7 hour job to start with. Yours should only take an hour.
Old Nov 7, 2003 | 12:25 AM
Faithful Old Road Dog's Avatar
When I change out hoses, after loosening the clamps, I'll take a utility knife and slice the hose lengthwise (as opposed to cutting it accross) at the connections. It makes it a whole lot easier to remove the old hoses from the fittings. Otherwise you'll risk the chance of damaging the brass connections or sweat joints. I guess it doesn't matter if you're replacing the heater core. Since you're changing out the hoses, you may want to check the fittings at the heater control valve for rot.
The Floor Guy
Oct 18, 2015 10:20 AM
f150rd
Dec 19, 2011 07:55 AM
jobguy
Apr 25, 2011 09:23 PM
Vicmacki
Bronco II
Aug 27, 2009 03:25 PM
rguy
1978 - 1996 Big Bronco
Jan 31, 2007 06:57 AM
