Bronco II Ford Bronco II
89 B2 Heater Core
Old Aug 25, 2009 | 04:37 AM
Vicmacki's Avatar
Vicmacki
89 B2 Heater Core
Im guessing since my interior reeks of anti freeze. And whenever i turn on my heater i get mass amounts of steam coming out of my vents. That i have a bad heater core.
My question is has anyone had any experience changing one out? Does the entire dash have to come off?
Any tips would be appreciated.
Thanks
Old Aug 25, 2009 | 09:36 AM
mrshorty's Avatar
mrshorty
B2's are pretty easy: a few bolts to open the heater core housing, disconnect the hoses, and the heater core comes out the bottom. The instructions in Haynes/Chiltons are all you should need for this operation on a B2.
Old Aug 26, 2009 | 01:19 PM
Vicmacki's Avatar
Vicmacki
Sounds easy enough
Thank you
Old Aug 27, 2009 | 01:36 AM
rebocardo's Avatar
rebocardo
No, but, on the 1989/1990 B2 I am pretty sure you have to remove the glove box because the A/C system is different from 1984/1988 and it is the only way to completely remove the duct.
Old Aug 27, 2009 | 03:25 PM
Eddiec1564's Avatar
Eddiec1564
On my 89 B2, I allready have the dash assy out(fixing that rusty leaking firewall seam), The heat/ac box has a access door with 4 screws(possable more) on the bottom of the heat box where the core is located. I don't think you have to take the glove box out as the cover and core looks lower than the glove box. After the heater hoses are removed the core should lever back into the duct work for the hose bibs to clear and the whole thing should drop stright down. Then its a good time to clean out any crap thats gotten in there before a new heater core goes in!
f100jim
General Automotive Discussion
Dec 8, 2014 12:16 PM
4x4 Bart
44
Mar 7, 2014 12:39 PM
genscripter
Nov 14, 2012 08:15 AM
cws10190
Jun 17, 2012 06:11 PM
JHAM
Jan 13, 2011 09:12 PM
