Sponsored by: Kumho
wheel width
Old Mar 11, 2022 | 10:51 AM
66f250's Avatar
66f250
wheel width
I'm looking for a set of factory stock 15" steel wheels that I can put back on my 67 f100, and run my factory poverty caps. The question I have is. Does anyone know what the width is of the factory wheels from the 60s and 70s, and is that an outside measurement or an inside measurement? I know I can buy 15x8 from wheel vintiques, but does 1" make that much of a difference? I'm trying to figure what size tires I can run.
Thanks guys.
Old Mar 11, 2022 | 12:54 PM
85e150's Avatar
85e150
'67 might be 5 1/2 or 6. Go with the 8s unless you are looking for the oem "too small " look.
Old Mar 11, 2022 | 02:49 PM
66f250's Avatar
66f250
Are they all the same in the 70s or did they make them wider?
Old Mar 11, 2022 | 06:58 PM
85e150's Avatar
85e150
I would expect the '70s might have moved to 6 inch, with 15x7s showing up in some trims or options--full size Broncos iirc.
What size tire are you thinking of?
Exploders came with a 15x7 wheel using a 235-75x15 tire, so IMO 15x7 would be the minimum I would go with.
If you are going with the bigger tires, 8" would be better for 31-10.50s which is about the biggest thing that will fit without lifting or trimming.
Old Mar 11, 2022 | 08:42 PM
66f250's Avatar
66f250
yes I was wanting to go 31x10.5r15
irydasteelhorse
Feb 8, 2018 06:06 PM
GM4WALLS
Apr 4, 2013 07:18 PM
jakerz
Aug 15, 2011 09:52 PM
BrianFX4
2004 - 2008 F150
Sep 8, 2007 03:14 AM
Dlinzy
Jun 26, 2007 09:29 AM
